Offline OchkovVF
#1 Posted : 07 September 2023 17:05:14(UTC)
OchkovVF
Was thanked: 28 time(s) in 27 post(s)
My students were building a multifocal ellipse and... almost went crazy. My ellipse is correct, but the student's is incorrect. Although the formulas are the same.
Can you guess where the error is and whether it is necessary to modify SMath so that such an error is visible?
Do you know more some examples?
Ellipse4.sm (12kb) downloaded 10 time(s).
Edited by moderator 08 September 2023 12:53:02(UTC)  | Reason: marked as SOLVED (not a bug)
Offline PompelmoTell
#2 Posted : 07 September 2023 17:47:49(UTC)
PompelmoTell
In fact only apparently the written formula is the same but in the first case "S" is outside the summation while in the second case it is inside the summation. You can verify this by copying and pasting the two formulas into a text editor.
thanks 1 user thanked PompelmoTell for this useful post.
on 07/09/2023(UTC)
Offline alyles
#3 Posted : 07 September 2023 17:58:54(UTC)
alyles
United States
Further illustrated by adding parenthesis around the summation in each formula
#4 Posted : 07 September 2023 18:00:34(UTC)
You can also select/double-click the sum symbol to check what belongs to it.
on 07/09/2023(UTC),  on 07/09/2023(UTC)
Offline oscampo
#5 Posted : 07 September 2023 18:01:59(UTC)
oscampo
Colombia
The problem is that in the first Ellipse(x,y) definition, variable S is outside Sum function, but in the definition of your students is inside:
Your definition:
Ellipse(x,y):sum(sqrt((x-el(X.F,i))^2+(y-el(Y.F,i))^2),i,1,N)-S
Student´s definition:
Ellipse(x,y):sum(sqrt((x-el(X.F,i))^2+(y-el(Y.F,i))^2)-S,i,1,N)
Maybe, this explicit form is most clear for students:
Edited by user 07 September 2023 18:06:56(UTC)  | Reason: Not specified
thanks 1 user thanked oscampo for this useful post.
on 07/09/2023(UTC)
Offline OchkovVF
#6 Posted : 07 September 2023 19:43:13(UTC)
OchkovVF
Better so
thanks 1 user thanked OchkovVF for this useful post.
on 08/09/2023(UTC)
Offline Razonar
#7 Posted : 07 September 2023 20:24:15(UTC)
Razonar
Uruguay
Was thanked: 828 time(s) in 525 post(s)
Originally Posted by: OchkovVF Go to Quoted Post
Better so ...
You can tell your students that you are using the Note under Example 3 of point 7.1.3 of ISO 80000-1:2009(E) Quantities and units, Part 1: General.
Edited by user 07 September 2023 20:26:28(UTC)  | Reason: Not specified
Offline OchkovVF
#8 Posted : 07 September 2023 21:28:30(UTC)
OchkovVF
It if Mathcad 15
1 ln(x)
2 ln*x - why not
