Ref: Example 12.2 (Page 296) - Soil Mechanics : Principles and Practice by G.E. Barnes. The attached SM file demonstrates how to find cutting points of strips with the slope profile and slip circle. (for an assumed strip width of 1m. which can be changed if necessary). Slip_Circle_Barnes-Ex 12.2-TO FORUM.pdf (239kb) downloaded 51 time(s). Slip_Circle_Barnes-Ex 12.2-TO FORUM.sm (321kb) downloaded 40 time(s).Edited by user 16 September 2023 11:04:08(UTC)
2 users thanked ndtma for this useful post.
on 16/09/2023(UTC), on 31/10/2023(UTC)
A small text correction to my post #1. Sorry for inconvenience please. Point A and Toe are also same. Edited by user 16 September 2023 13:54:36(UTC)
on 16/09/2023(UTC), on 17/09/2023(UTC)
Hi, Second correction, as the variable Hvc is no longer used in the entire program. Please delete the entire line as indicated. Extremely sorry. |
3 users thanked ndtma for this useful post.
on 20/09/2023(UTC), on 20/09/2023(UTC), on 20/09/2023(UTC)
Hi, Please make the correction as shown ( replace A with -A in page 3). Even without this correction, the program will run in most cases, but will give wrong values for AA for some center cordinates. This correction is an improvement. Sorry for the inconvenience. Edited by user 21 September 2023 13:48:20(UTC)
1 user thanked ndtma for this useful post.
on 29/10/2023(UTC), on 29/10/2023(UTC), on 30/10/2023(UTC)
