Offline OchkovVF
#1 Posted : 19 November 2023 22:02:27(UTC)
OchkovVF
Was thanked: 28 time(s) in 27 post(s)
Is it my or SMath error?
I'm used to typing the unit like this. I type, for example, m or kg and press tab. But it’s not a unit m, but a user variable m.
Check please!
Offline ioan92
#2 Posted : 19 November 2023 23:43:26(UTC)
ioan92
France, Metropolitan
Was thanked: 153 time(s) in 119 post(s)
Check please!
You point a wrong problem.
There is no error. First "m" is the name of a variable named by "m", with the content affected by you of 1kg. The second "m" in blue is a unit name for the meter.
Everything is right with the only condition to use them in the appropriate place.
It is easy to differentiate the two because the units are (by default) colored in blue.
Edited by user 19 November 2023 23:48:25(UTC)  | Reason: Not specified
thanks 1 user thanked ioan92 for this useful post.
on 19/11/2023(UTC)
Offline OchkovVF
#3 Posted : 19 November 2023 23:57:33(UTC)
OchkovVF
I type the letter m and then press the tabulator. The meters must be entered, not the user variable m.
The dropdown list of variables starting with the letter m can be disabled!
If I enter a variable m, then I don’t need to press the Tab key!
I wrote about this error to the developer!
Edited by user 19 November 2023 23:59:43(UTC)  | Reason: Not specified
Offline ioan92
#4 Posted : 20 November 2023 04:26:16(UTC)
ioan92
I dislike being unpolite but, IMHO, you persevere on being wrong.
If you hadn’t affected the letter “m” to a variable, your expectation was been exhausted.
The SMath list is intended to help you on avoiding any error.
Offline OchkovVF
#5 Posted : 20 November 2023 04:42:57(UTC)
OchkovVF
Let's wait for the answer from the developer (Andrey Ivashov), who personally taught me that if I type the letter m and press the Tab key, I will get a meter.
#6 Posted : 20 November 2023 04:49:16(UTC)
Just type an apostrophe '. Then the placeholder switches from rectangle to oval shape and the dynamic assistant just displays units.
Even without typing the ' you can still use the dynamic assistant but you will have to navigate with the arrow keys before confirming your selection with tab.
on 20/11/2023(UTC),  on 20/11/2023(UTC)
#7 Posted : 20 November 2023 08:11:54(UTC)
Doing right/wrong is a matter of choice.
Thermies:=1 ... 1 is a multiplier of your choice
copy Thermies, paste in the empty place holder of result.
Offline OchkovVF
#8 Posted : 20 November 2023 08:34:19(UTC)
OchkovVF
Однажды возле дома ходжи рассорились два его соседа. Хай подняли такой, что ходжа был вынужден выйти к ним. Он отвел первого в сторонку. Тот изложил ему все и в конце спросил: "Ну как? Разве я неправ?" Ходжа охотно поддержал его: "Ты прав, братец! Сейчас я обьясню этому шакалу, что ты прав. Иди спокойно себе". Ходжа подошел ко второму, тот рассказал ему дело, разумеется, пристрастно, в выгодном для себя свете. "Ну, ходжа, что ты скажешь? Разве я не прав?" Ходжа ответил: "Конечно, ты прав! Я ему так и обьяснил, собаке, и он, видишь, понял твою правоту и ушел устыженный!".
Ходжа довольный вошел домой, но тут жена потребовала обьяснений: "Эфенди, я тут слышала все, говорили вы возле окна. Как же это получается? И тот прав, и этот прав! Разве могут быть правы одновременно два спорящих человека?" Ходжа спокойно сказал: "И ты права, жена! Успокойся"
#9 Posted : 21 November 2023 05:20:17(UTC)
How can two arguing people be right at the same time ?
They argue top/down ... down/top.
Ducks dine bottom up.
Unit system is very poor for Process Control Instrumentation
m/s ... kg/m³ ... T/hr
You know how to characterize specific user units
Cheers ... Jean.
Inst_CornThermies [PROCEDURE].sm (72kb) downloaded 3 time(s).
Offline Kenny Lemens
#10 Posted : 21 November 2023 13:57:19(UTC)
Kenny Lemens
United States
Greetings,
What Mr. Ivashov says is true for most cases; open a new worksheet and keypress 「m」 + 「TAB⭾」, you will get the units m as meters (ie., 「'm」 ). The issue you are facing is due to your declaration of "m", thus your variable is added to the Dynamic Assistant and and since you typed in 「m」, it only makes sense that you are able to use the variable you created.
Maybe this will help you, what Mr. Ivashov said is a rough rule of thumb, the 'correct procedure' to enter in meters is one of the following ways:
  1. Use the [Insert] menu ; [Unit...]
  2. Type the unit directly: keypress: 「'」 + 「m」
  3. Activate the 'Active Dynamic Assistance' (i.e., keypress: 「Ctrl」 + 「Space」)
    • Scroll down until the desired entry has focus
    • Keypress 「TAB⭾」 (or 「Enter⮐」) to insert item into worksheet
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
thanks 2 users thanked Kenny Lemens for this useful post.
on 21/11/2023(UTC),  on 21/11/2023(UTC)
