#1 Posted : 22 November 2023 07:22:45(UTC)
Why does the vectorize operation fail while it seems to be safe to use an explicit loop?
6-2-Bug.sm (28kb) downloaded 7 time(s).
Offline Razonar
#2 Posted : 22 November 2023 08:41:12(UTC)
Razonar
Uruguay
Was thanked: 828 time(s) in 525 post(s)
Hi Martin. Because you have just only one function which can't be vectorized: the norme or dot product of vectors.
thanks 3 users thanked Razonar for this useful post.
on 22/11/2023(UTC),  on 22/11/2023(UTC),  on 22/11/2023(UTC)
#3 Posted : 22 November 2023 10:35:34(UTC)
Is that just by observation or is there a fundamental obstacle?
Offline Razonar
#4 Posted : 22 November 2023 12:57:58(UTC)
Razonar
Uruguay
Hi. I guess that it is fundamental.
Some notes about how other CAS handle this issue.
Pretty old matlab version, from its symbolic toolbox
The help page from the newest version
So, it looks like they have some issues with automatic vectorization.
With maple it is very uncomfortable, you need to use map even for simple cases
Wolfram's solution is very practical: Function with attribute 'Listable' expands over lists
But for make a table you actually need a loop or the Mathematica's Map function.
thanks 2 users thanked Razonar for this useful post.
on 24/11/2023(UTC),  on 26/11/2023(UTC)
#5 Posted : 26 November 2023 02:15:21(UTC)
Why does the vectorize operation fail while it seems to be safe to use an explicit loop ?
Set the demand in local definition mode ...
new(t):=|a(t)
vectorize and equate
6-2-Bug Doctored.sm (30kb) downloaded 4 time(s).
on 26/11/2023(UTC)
#6 Posted : 26 November 2023 05:17:47(UTC)
Thanks Alvaro and Jean. Here is a reduced working example.
When a scalar function involves scalar products then it must be defined in a line()-block in order to be vectorize()able.
Worksheet13.sm (6kb) downloaded 6 time(s).
on 27/11/2023(UTC)
