SMath Studio Forum
Bugs & Problems
Three equations and more unknown variables
Hello All, I have four unknowns in three linear equations. In this setup, can the FindRoot function get values for these variables? I tried the same in MathCAD and could get the solution, but it is not working in Smath. Can someone guide me, please? Are there other possible solving methods for handling such equations with 6 or 8 unknowns? Trial.sm (38kb) downloaded 13 time(s).[a Trial.sm (38kb) downloaded 13 time(s).ttach]48521[/attach] Trial.sm (38kb) downloaded 13 time(s).Best Regards Saviind
Usually al_nleqsolve() is more capable at this kind of situations. Also your functions shouldn't have boolean operations. Regards
Solve() from the Maxima plugin can handle under-determined systems of equations. In such cases, the solution contains a free variable. The name changes every time the sheet is recalculated. If you want to rely on that name, insert a MaximaControl("restart" ) command to reset the Maxima session and the counter. Trial_Kr.sm (42kb) downloaded 9 time(s). |
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 828 time(s) in 525 post(s)
Originally Posted by: Saviind ... I tried the same in MathCAD and could get the solution, but it is not working in Smath.... Hi. Can you share the Mathcad result? This page is the help for matlab techniques for handling underdetermined systems: https://www.mathworks.co...r-equations.html#bt7ov7uWriting the system as a linear one, SMath have some functions for work with those systems, like this one Trial.sm (62kb) downloaded 7 time(s).Best regards. Alvaro.
For your f(x,y,z) ... I get two sets of solved [x,y,z]. Smath solves the Mathsoft example, 4 unknowns. Smath Butller is lot more advanced/difficult. Jean. Solve FindRoot f(x,y,z) ITERATIVE.sm (104kb) downloaded 11 time(s).
SMath Studio Forum
Bugs & Problems
