SMath Studio Forum
Questions
exportDataCSV doesn't work in .exe file
Joined: 19/12/2023(UTC) Posts: 4 Was thanked: 1 time(s) in 1 post(s)
Hello, I use exportDataCSV (D; fname; path) to write data to a file. It works from SM and Preview SMath Viewer. But when I create an exe file, the data is not saved. I discovered in the log file that an error is being generated. 18.12.2023 14:12:19 [INFO ] [Plugin.Initialize()] SMath Studio Desktop 64-bit 1.0.8348.30405 18.12.2023 14:12:19 [INFO ] [Plugin.Initialize()] Cephes Mathematical Library, version 1.0.8034.38340, 30-gruod.-2021 21:18:00 18.12.2023 14:12:19 [INFO ] [Plugin.Initialize()] OS: Microsoft Windows NT 6.2.9200.0 18.12.2023 14:12:19 [INFO ] [Plugin.Initialize()] .Net: 4.0.30319.42000 18.12.2023 14:12:19 [ERROR] [Plugin.Initialize()] The system cannot find the file specified. (Exception from HRESULT: 0x80070002)
A file of 2000 integers is recorded about 25 seconds. Is this normal?
Thanks in advance.
I think the problem is in the the Cephes Mathematical Library; if you create an executable without that library exportData.csv should work. |
David, thanks for replay. I disabled the Cephes Mathematical Library. Now the file is not created in all cases.
Originally Posted by: Nesvarbu Now the file is not created in all cases. I've made a simple test file and it works. WorksheetTest.sm (4kb) downloaded 3 time(s).If you post a small example that doesn't works for you I might try to find the cause and fix the plugin. |
David, I've posted almost full file. Another thing that seems strange to me is the very long (~ 2 min) saving to file time. Eksponentes_V5.sm (20kb) downloaded 7 time(s).. The WorksheetTest works. Edited by user 28 December 2023 05:10:51(UTC)
The problem has been solved. But its cause has not been eliminated. It was enough to change the Round (A) function to Round (A;0). There was no problem with the speed of writing, either.
1 user thanked Nesvarbu for this useful post.
SMath Studio Forum
Questions
