Offline Ale_Biaso
#1 Posted : 09 January 2024 14:45:31(UTC)
Ale_Biaso
Hi to everybody.
I've got a problem with an interactive assessment of a parameter.
I'm not able to set in the correct manner a "for Cicle".
The general problem is this one
I need to set an initial lenght L0=6b, than
-if the ratio between y/b<0.1 the cicle end and i obtain the value that i need (y and L);
- if the ratio between y/b>0.1 and <0.6 i need to continue the cicle until convergence
I'm not able to set the correct fuunction
Someone can help setting for me the formulation?
I attach the file below, need to be open with the related excell
413-Camino Alabama-Modale_R1.xlsx (301kb) downloaded 10 time(s). 413-Camino Alabama-Vento_R2.sm (5,667kb) downloaded 10 time(s).
Thancks in advance for any answere!
thanks 1 user thanked Ale_Biaso for this useful post.
on 10/01/2024(UTC)
Offline ioan92
#2 Posted : 10 January 2024 23:14:49(UTC)
ioan92
France, Metropolitan
Was thanked: 153 time(s) in 119 post(s)
Hi Ale_Biaso,
Happy New Year to You and to all SMath users and developers!
1. Congratulations for your interesting and useful work.
2. Thanks for the extensive publication of this work.
3. It is not a simple task to check it all. That’s why I kept my first attention to identify the reasons of “red-marked” errors on your sm file.[/list]
4. Here are some identified reasons of such errors.
Simple pragmatic suggestion: when I have such errors, firstly I display the values of each term to see if they are already defined:
d is not an index; L is not defined, etc !
5. I keep ready to look for a further evolution of your work.
Best Regards,
Ioan
PS: If I may adding some suggestions it will be:
* For the working phase, I use "no limits pages" screen
* Separate "the cosmetics aspects" from the basic robust algorithm. Keep this for a distinct operation...
Buona Fortuna,
Ioan
Edited by user 11 January 2024 05:38:41(UTC)  | Reason: Not specified
#3 Posted : 11 January 2024 04:56:15(UTC)
Originally Posted by: Ale_Biaso Go to Quoted Post
Hi to everybody.
I'm not able to set in the correct manner a "for Circle"
Recast as suggested by Ioan ... attach.
Generally, Bolean must be specified completely.
Sometimes, immaterial.
Offline Ale_Biaso
#4 Posted : 11 January 2024 12:41:20(UTC)
Ale_Biaso
Hi to everybody.
I reply here to your advices.
I tried to semplify the spreadsheet in order to focus aptention on the iteractive process that i'd like to assess.
I explicate even the main process that i tried to set into formulation but that doesn't works because i don't understand the correct syntax of a "for cicle"
All my consideration are into the smath file and summaryzed below.
If someone have time to take a look and fix the mistakes of the cicle only i'll be very gratefull.
I attached the simplify file below (always need to be opend in the same folder of related excel)
Ciclo for semplificato_R1.sm (5,612kb) downloaded 7 time(s).
413-Camino Alabama-Modale_R1.xlsx (301kb) downloaded 5 time(s).
Thancks for your time
Offline PompelmoTell
#5 Posted : 12 January 2024 00:16:41(UTC)
PompelmoTell
In fact I see at least two incorrect or suspicious situations:
1) what appears to be an assignment is performed with = instead of :=
2) j of the for loop is a counter but here it is referred to as a series of values ​​with units of measurement. I'll show you a simple working example
#6 Posted : 12 January 2024 01:22:50(UTC)
Hi Ale,
That's one way to do it (a backbone)
2024-01-11 12_16_00-Cicle for interaction - Mozilla Firefox.png2024-01-11 12_22_05-SMath Solver - [loop.sm].png
P.S. I'd suggest to use the multiple if/else instead of the nested if/else to improve the readability (just add more argument separators in the standard if/else)
Offline Ale_Biaso
#7 Posted : 12 January 2024 22:34:37(UTC)
Ale_Biaso
Thacks a lot for your advices!
