Offline JonAReynolds
#1 Posted : 14 January 2024 03:18:45(UTC)
JonAReynolds
United Kingdom
Is it possible to change the way in which a worksheet is displayed?
It is presented as a series of pages, with gaps in between. Regions will not span the gaps, and so large empty areas appear. I find this very irritating. Is it possible to prevent or hide these gaps, giving a continuous display, effectively using a page of infinite length?
TIA
Jon
#2 Posted : 14 January 2024 05:41:22(UTC)
Originally Posted by: JonAReynolds Go to Quoted Post
Is it possible to change the way in which a worksheet is displayed ?
It is presented as a series of pages, with gaps in between.Regions will not span the gaps, and so large empty areas appear.I find this very irritating.Is it possible to prevent or hide these gaps, giving a continuous display, effectively using a page of infinite length
The Smath default is infinite length. Not convenient for printing, PDF.
Go to Page Setup ... all 9.91 for normal Work Sheet system.
For convenience, separate region(s) from Insert Separator.
Offline ioan92
#3 Posted : 14 January 2024 05:50:08(UTC)
ioan92
France, Metropolitan
Was thanked: 153 time(s) in 119 post(s)
Hi Jon,
You can choose the printing option: "No bounds"
from the right side of the page bottom:
In this way you can settle your work as you want.
Ioan
#4 Posted : 14 January 2024 08:26:02(UTC)
JonAReynolds
United Kingdom
Thank you Ioan, that's exactly what I need.
I'd never even noticed the bit at the bottom RH corner. Sometimes I get the feeling that one can do a lot in Smath, but it's a bit like an MI5 puzzle to find some things!
Thanks again.
Jon
Edited by moderator 16 January 2024 01:02:17(UTC)  | Reason: marked as SOLVED
