I'm pretty sure it's possible and saw it somewhere here. How do I put this in a single matrix, along with the descriptors like "roof angle, "1", "2E",...etc. and use it for interpolation. Well I can get by using a single column matrix as a work around but I guess I want a more compact looking solution, if that makes sense. Edited by user 17 January 2024 22:02:09(UTC)
Look for InterpBilinear() function. You can find more info in Reference Book. Regards InterpBilinear.sm (9kb) downloaded 9 time(s).Edited by user 17 January 2024 22:07:05(UTC)
ohh didn't know about that. big thanks.
Using linterp() with a function is another way. Function selects column according to input. Regards linterp_select.sm (9kb) downloaded 8 time(s).
I'm quite satisfied with the InterpBilinear function. I'm exploring Jean's and overlord's additional suggestion but still it was already solved for me. Another question is that would that still work if I had to do interpolation in both the column values and row values such as in case below. From what I understand, InterBilinear() seems incapable of doing what I aim to do. Do you have any suggestions?
Originally Posted by: GFDIntano From what I understand, InterBilinear() seems incapable of doing what I aim to do. Do you have any suggestions ? If, I understand your request, ForLoop algo style will do ... last example page 10.Jean Interpolate [Linterp, Spline2D].sm (213kb) downloaded 2 time(s).
Originally Posted by: GFDIntano From what I understand, InterBilinear() seems incapable of doing what I aim to do. Do you have any suggestions? On the contrary, InterpBilinear() does exactly what you seek. It interpolates both row and column values. PS: I added extra values to accommodate ≤ and ≥ boundaries. Regards
Originally Posted by: GFDIntano I want a more compact looking solution, if that makes sense.
Visit Samples for bidirectional interpolating Matrix. Jean
