Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 348 Was thanked: 28 time(s) in 27 post(s)
This is because the solution functions are defined using interpolation. The interpolation functions have the X and Y vectors and the value of x as arguments. You try to provide a vector for x. Vectorize can handle only matrix arguments of the same size and successively calls the function with the j-th element of each vector. So vectorize would require your x vector to be of the same size as the data vectors. Even in this case this probably will fail because the data would be reduced to a single X_i and Y_i. Therefore, you have to use a loop. |
Vectorize works fine in this document. Three-Planets.sm (42kb) downloaded 7 time(s).
Originally Posted by: Jean Giraud Vectorize works fine in this document. Three-Planets.sm (42kb) downloaded 7 time(s). Sorry - no. See please the attach Three-Planets.sm (40kb) downloaded 14 time(s).
Originally Posted by: OchkovVF Sorry - no. See please the attach As I open your returned document, both vectorize are red ... click on either one ... Bingo
