Hello. Tell me, please, is it possible to see the set numerical values when calculating formulas in the program? I mean, instead of a = 5, b = 6, a + b = 11
see a = 5, b = 6, a + b = 5 + 6 = 11
Joined: 27/03/2019(UTC) Posts: 75 Location: coah Was thanked: 27 time(s) in 22 post(s)
In the simplest case, this option would be suitable, but if the formula is a little more complicated, then we get a pile of fractions and numbers
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 509 time(s) in 339 post(s)
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings, Alvaro has built a function to address this feature request: Note: it has a little bit of a learning curve, but is worth considering never-the-less. May this be of Good Help; ⚜ Kenny Lemens, P.E. ᵂᴵ |
Originally Posted by: Kenny Lemens Note: it has a little bit of a learning curve, but is worth considering never-the-less. I don't see the result in the attached screenshots of how it works. A jumble of formulas where there is no clear answer.
