Hi all, I want to create a simple 2-D filled (color-coded) contour plot to show deformation at various points across a mat foundation. The data would look as follows (x and y are the coordinates, z is the deformation):
x,y,z
0 m,0 m,50 mm
0 m,60 m,65 mm
30 m,20 m,120 mm
0 m,40 m,80 mm
30 m,40 m,150 mm
60 m,40 m,80 mm
30 m,60 m,100 mm
0 m,80 m,40 mm
60 m,80 m,50 mm
Is there a way to do this in SMath? I remember there being a straightforward way in Mathcad to do the same thing, but I can't seem to figure it out in SMath.
Thanks in advance.
