Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 348 Was thanked: 28 time(s) in 27 post(s)
I feel like it's not quite the center of mass. If n=3 then this is the Fermat point. How to find the center of mass of a set of points forming a plane figure? Gravity-Center.sm (75kb) downloaded 7 time(s).What is the name of the Fermat point if n > 3? Edited by user 09 May 2024 23:19:20(UTC)
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 830 time(s) in 526 post(s)
Hi Valery. This could be an option: Using discrete contours you can see this Martin post. Best regards. Alvaro.
