SMath Studio Forum
Questions
IF ELSE VERSUS CASES FORMALISM
Joined: 03/06/2023(UTC) Posts: 57 Was thanked: 1 time(s) in 1 post(s)
Help would be appreciated. I cannot make a chain of if-else statements equal to the cases formalism. What am I missing. I have tried the less than or equal only in the cases formalism. That didn't work either. The if-else results are correct, the cases formalism is not correct. IF ELSE VERSUS CASES FORMALISM.sm (13kb) downloaded 4 time(s).Thanks for any help. Reg |
Reg Curry Loveland, CO
Oops sorry. I had errors in my formulas. Here is the corrected version where the two formalisms do agree. IF ELSE VERSUS CASES FORMALISM.sm (13kb) downloaded 6 time(s).Sorry |
No problem, when possible, better ask. I would point out that currently you can avoid the nested if/else and convert it in if/else if/else (if you wish), simply adding more arguments. As side note if you delete an argument from the default if/else, you'll get an if without else. IF ELSE VERSUS CASES FORMALISM(2).sm (17kb) downloaded 14 time(s).Also, since the topic is about if/else vs cases, I would like to highlight that cases has a different coding approach to evaluate in some situations where if/else is not allowed to; this feature comes at the cost that you shouldn't make assignments ( : ) inside its arguments, while in if/else you can safely build block of codes inside it using the line function (see here and here for examples). Edited by user 10 May 2024 10:15:37(UTC)
| Reason: small clarification |
Davide, Thanks much. Very helpful as always. Reg |
SMath Studio Forum
Questions
