7 Pages<1234>»
#21 Posted : 10 February 2013 20:25:48(UTC)
I guess the problem is that in the example the variable V is not just a system but an expression involving systems. There was a sys2mat version with just replacing the "sys" in the string representation (num2str) by "mat". In the given case, this approach would fail.
Perhaps the function sys2mat should internally apply eval() and then do the replacement.
Martin
#22 Posted : 12 February 2013 01:11:20(UTC)
PLUGIN UPDATED
- fixed issue of sys2mat() involving sys() special features (many thanks to mkraska Offline )
best regards,
w3b5urf3r
on 13/02/2013(UTC)
#23 Posted : 17 February 2013 14:40:28(UTC)
The mat2sys function seems to be limited to column matrices. This might be a feature rather than a bug. In the first case I would recommend to be more specific in the doc string ("Converts column matrices (vectors) to systems" ). Alternatively, the linear indexing feature could be used to flatten the matrix.
on 17/02/2013(UTC)
#24 Posted : 17 February 2013 21:45:16(UTC)
Hi Martin Good
Yes, actually mat2sys function is limited to column matrices (the function brutally changes "sys(" to "mat(", without checks).
An improvement will be available ASAP.
best regards,
w3b5urf3r
on 18/02/2013(UTC)
#25 Posted : 20 February 2013 18:56:19(UTC)
PLUGIN UPDATED
- mat2sys() now can handle also non-column matrices (nested or not)
- sys2mat() symbolical enhancements
regards,
w3b5urf3r
Edited by user 20 February 2013 20:04:23(UTC)  | Reason: Not specified
on 21/02/2013(UTC)
#26 Posted : 15 March 2013 14:05:31(UTC)
PLUGIN UPDATED
  • added new texts functions:
    • strtolower(1): converts all characters in a string to lowercase;
    • strtoupper(1): converts all characters in a string to uppercase;
    • ucfirst(1): converts the first characters in a string to uppercase;
    • ucwords(1): converts the first characters of each word in a string to uppercase;
    all functions works both with texts or texts nested in arrays/systems;
  • added norme(): unofficial patch of SMath Studio norme() function (BUG shown here);
  • sys2mat(): fixed unexpected influence on input arguments.
Plugin's Sources are moved to the SVN repository (I have added a link in the first post)
regards,
w3b5urf3r
Edited by user 15 March 2013 14:12:48(UTC)  | Reason: Not specified
thanks 3 users thanked Davide Carpi for this useful post.
on 15/03/2013(UTC),  on 16/03/2013(UTC),  on 16/03/2013(UTC)
#27 Posted : 16 March 2013 22:59:58(UTC)
Hi Davide,
thanks for the update. I added the functions to the function reference in the handbook and also added a section on string functions.
The norme replacement is highly welcome. I just had a small problem, see attachment.
Just in case you are looking for distraction from real stuff like unit and systems proof solvers:
I'd vote for unit-proof versions of int(), Re() and Im() and arg().
Martin
File Attachment(s):
Matrizen.sm (74kb) downloaded 54 time(s).
#28 Posted : 16 March 2013 23:17:55(UTC)
Thank you Martin;
the issue is related with some SMath bug involving transpose and the linear indexing feature Censored ... Tomorrow I'll look in the bug section to see if it has already been reported and I'll update the plugin with your formula Good
File Attachment(s):
bug.sm (7kb) downloaded 51 time(s).
#29 Posted : 17 March 2013 14:40:20(UTC)
PLUGIN UPDATED
- fixed norme() issue involving transpose and the linear indexing feature;
- enhancements of ucwords(): now accept all Unicode white spaces as separator of words.
best regards,
w3b5urf3r
on 18/03/2013(UTC)
Offline sublim21
#30 Posted : 16 April 2013 16:58:33(UTC)
sublim21
Was thanked: 3 time(s) in 3 post(s)
Great job websurfer!
Would it be possible to change mat2sys such that it doesn't collapse nested matrices?
Please see attached
Edited by user 16 April 2013 18:34:00(UTC)  | Reason: Not specified
File Attachment(s):
sys2mat_suggestion.sm (6kb) downloaded 60 time(s).
#31 Posted : 16 April 2013 18:14:06(UTC)
Originally Posted by: sublim21 Go to Quoted Post
Would it be possible to change sys2mat such that it doesn't collapse nested matrices?
That won't work as list nesting is not persistent:
sys(sys(1,2,2,1),3,2,1)=sys(1,2,3,3,1)
mat2sys could, however, have an option to restrict the conversion to the outer level matrix and leave all entries as they are.
Offline sublim21
#32 Posted : 16 April 2013 18:35:06(UTC)
sublim21
mkraska, you're right. sys2mat was a typo. Thanks!
#33 Posted : 23 April 2013 11:31:11(UTC)
PLUGIN UPDATED
- fixed norme issue with 1x1 matrices
- UoM now get the units element-by-element from any matrix/system (nested or not)
best regards,
w3b5urf3r
#34 Posted : 23 April 2013 17:54:12(UTC)
#35 Posted : 04 June 2013 09:46:56(UTC)
A Nightly update for anyone are using SMath Studio 0.96.4902 (plugins -> online gallery)
- removed norme clone (not needed anymore)
- added not recursive mat2sys.1(#)
- added not recursive sys2mat.1(#)
best regards,
w3b5urf3r
File Attachment(s):
customFunctions_examples.zip (5kb) downloaded 65 time(s).
on 04/06/2013(UTC)
#36 Posted : 27 December 2013 16:29:52(UTC)
mat2sys requires the argument to be literal matrices. Matrix-valued expressions need to be evaluated first either by assigning them to a variable or by wrapping them in eval(). A similar issue has been reported for sys2mat and has been solved.
I propose to transfer the solution to mat2sys.
on 28/12/2013(UTC)
#37 Posted : 01 March 2014 19:12:08(UTC)
UPDATED
- new function: InterpBilinear()
- new function: GetType()
- mat2sys() improvements for 1x1 matrices
(examples attached in the first post)
Edited by user 01 March 2014 19:29:37(UTC)  | Reason: Not specified
2014-03-01 17_13_27-SMath Studio Desktop - [CustomFunctions_examples.sm_].png
on 01/03/2014(UTC),  on 02/03/2014(UTC)
#38 Posted : 23 June 2014 01:42:25(UTC)
PLUGIN UPDATED
- added strsplit("string","delimiter" )
Best regards,
Davide
Edited by user 23 June 2014 01:46:02(UTC)  | Reason: Not specified
on 23/06/2014(UTC)
Offline uni
#39 Posted : 23 June 2014 11:17:53(UTC)
uni
Davide, try string.Join().
Russia ☭ forever
Viacheslav N. Mezentsev
on 23/06/2014(UTC)
#40 Posted : 23 June 2014 12:37:48(UTC)
Thank you Viacheslav Good
Done: added strjoin(2)
Best regards,
Davide
on 23/06/2014(UTC),  on 23/06/2014(UTC)
Guest (2)
Similar Topics
[Custom Functions plugin] cases SS6179 (Bugs & Problems)
by PompelmoTell 07/02/2017 19:14:23(UTC)
7 Pages<1234>»
