SMath Studio Forum
Bugs & Problems
[SS-3479] Attempted to divide by zero exceptions
Joined: 22/03/2013(UTC) Posts: 20 Location: Atlanta, GA
When I try to save a simple page it crashes SMath with a "Attempted to divide by zero." error. I got this error with the portable and installed version. The page works great until I try to save. I have attached a screen shot. Thanks, Kyle kda406 attached the following image(s):
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1332 time(s) in 876 post(s)
could you attach the file?
regards,
w3b5urf3r |
yes, can you attach it ? this is my version of your sheet, please tell us if you can run and save it.
regards,
w3b5urf3r Sure, it's attached. It won't open for me. Thanks, Kyle
Originally Posted by: kilele yes, can you attach it ? this is my version of your sheet, please tell us if you can run and save it. Thanks for the sample file. It does not open correctly for me. When I double click your file, I get what you see in the attached screen shot. Thanks, Kyle EDIT: I get the same problem below from your file in both installed and portable version.Edited by user 22 March 2013 20:00:59(UTC)
| Reason: Not specified kda406 attached the following image(s):
There might be some problem with the TextRegion.dll plugin. You may want to make a clean uninstall of SMath with some of this programs, all of them available for free at portableapps.com ZSoftUninstaller, IObitUninstaller, WiseRegistryCleaner.
Originally Posted by: kda406 Sure, it's attached. It won't open for me. Thanks, Kyle The file is broken - probably becasue the "Attemted to divide by zero" error has stopped the saving routines, but I'm not sure because last line is in the file header (TextRegion plugin), not in the body... The kilele file works for me; if both install and portable versions cause you issues you can try to install again the .NET framework 2.0 libraries. What OS are you using? Windows XP x86/x64 SP1/2/3? Davide Carpi attached the following image(s): |
Originally Posted by: w3b5urf3r_reloaded The file is broken - probably becasue the "Attemted to divide by zero" error has stopped the saving routines, but I'm not sure because last line is in the file header (TextRegion plugin), not in the body...
The kilele file works for me; if both install and portable versions cause you issues you can try to install again the .NET framework 2.0 libraries. What OS are you using? Windows XP x86/x64 SP1/2/3? This machine runs XP Pro x86 SP3 and has .NET 2.0, 3.0, 3.5, and 4 installed. .NET 2.0 has Service Pack 2. Thanks, Kyle
Originally Posted by: kilele There might be some problem with the TextRegion.dll plugin. I have only one copy of TextRegion.dll on my computer. It is located in C:\Program Files\SMath\SMath Studio\plugins. It is 23552 bytes in size and was made on July 30, 2012, 12:03:58AM. I uninstalled SMath Studio, and made sure the directory was removed (it was gone). I downloaded a fresh copy of the .msi installer and reinstalled. Same problems. Thanks, Kyle
Kyle, I suggested to use some of the uninstallers above because I had problems with an old SMath version which always disabled a plugin when loading. This kind of programs not only remove the installed files but also search for leftovers on the registry, this seemed to make SMath load with all plugins. Another thing that you could try is to install SMath in a different location than default, and also install several versions of SMath. Good luck!
I tried uninstalling and reinstalling in a different directory. This did not solve the problem. I uninstalled SMath altogether. I ran Piriform CCleaner ( here) and ran the registry cleaner and rebooted 3 times before all problems were fixed. All "problems" were minor and the result of uninstalled 3D CAD systems. I cleaned them all up until the computer rebooted, checked, and claimed "no problems." I installed 0.95.4594 again, and still have the exact same problem reading Kilele's Page1.sm. New info==> When I click Help -> About, I get a divide by zero error. This happens with both a new, blank page, and if I have Kilele's Page1.sm file open. Thanks for all the help guys, Kyle
You can try to install .Net4.5and also update the other .Net libraries present on your system. This should fix the problem Edit: My last shot, take the file TextRegion.dll out of its directory and run SMath, put it back and see if the problem is gone. Edited by user 28 March 2013 16:07:55(UTC)
Unfortunately, .Net 4.5 is not available for my XP Pro SP3. Thanks, Kyle
well actually SMath works with .net2 apart from the DataExchange plugin which has versions for .net2 and .net35, though later .net frameworks might have some effect on previous ones. Maybe you could find some update for these two .net versions from windows update of your operating system.
Originally Posted by: kilele My last shot, take the file TextRegion.dll out of its directory and run SMath, put it back and see if the problem is gone. I missed the edit earlier. I just tried this and it gives me the same drawing error after following your instructions. (Also the same divide by zero error when trying to view Help -> About) Thanks, Kyle
Have you tried if the issue affects also older SMath Studio versions? 0.95, 0.94, 0.93, 0.92.... |
I've noticed that if you delete some dlls, a reconfiguration window is brought up by SMath and the files are restored, I assume they are extracted from the program's exe. As a last resort, apart from upgrading .Net20, you may want to replace some files from your installation with these of mine: https://dl.dropbox.com/u...ract_to_smath_folder.zip
Originally Posted by: kilele Maybe you could find some update for these two .net versions from windows update of your operating system. "Windows Update" shows no updates available for my machine. This workstation is fully patched as far as I can tell. Looking at "Add or Remove Programs": Microsoft .NET Framework 2.0 Language Pack - DEU Microsoft .NET Framework 2.0 Service Pack 2 v2.2.30729 Microsoft .NET Framework 3.0 Service Pack 3 v3.2.30729 Microsoft .NET Framework 3.5 SP1 Microsoft .NET Framework 4 Client Profile v4.0.30319 Microsoft .NET Framework 4 Extended v4.0.30319 Thanks, Kyle
Originally Posted by: w3b5urf3r_reloaded Have you tried if the issue affects also older SMath Studio versions? 0.95, 0.94, 0.93, 0.92.... I see I neglected to mention above I downloaded and tried an earlier version and it had the same problems. I think it was 0.93 (sorry I didn't keep it to remember). I will try the files in the zip next... Thanks, Kyle
Originally Posted by: kilele I've noticed that if you delete some dlls, a reconfiguration window is brought up by SMath and the files are restored, I assume they are extracted from the program's exe. As a last resort, apart from upgrading .Net20, you may want to replace some files from your installation with these of mine: Your plugins directory had tons of files which mine did not have. I extracted your and told Winzip to overwrite mine. Then I noticed you included some .sm files in the plugins directory. I opened the larger one in SMath, which you can see in the attached. Thanks, Kyle kda406 attached the following image(s):
SMath Studio Forum
Bugs & Problems
