Hi all, I noticed that the output of the eval() function is related in some way to the decimal places setting... Don't know if it's a bug or a feature, but seem it's not a rule (see the screenshot) IMHO it's preferable to cancel this behavior... best regards, w3b5urf3r Edited by user 28 May 2013 11:59:59(UTC)
| Reason: Not specified File Attachment(s): eval.sm (9kb) downloaded 16 time(s). Davide Carpi attached the following image(s): |
I might not quite understand your point, but I think this is a matter of rounding to some number of decimal places and it is ok with me when I put 1.05 and us 1 decimal place to see: 1.05=1
Regards, Radovan |
Originally Posted by: omorr I might not quite understand your point, but I think this is a matter of rounding to some number of decimal places and it is ok with me when I put 1.05 and us 1 decimal place to see: 1.05=1
Regards, Radovan I'm not sure... File Attachment(s): eval.sm (45kb) downloaded 17 time(s). Davide Carpi attached the following image(s): |
Sorry, Davide - I do not get it And where all those fractions come from. I delete them, press equal to - and got the fixed/exponential numbers Regards, Radovan Edited by user 28 May 2013 16:31:13(UTC)
Originally Posted by: omorr Sorry, Davide - I do not get it Maybe I'm wrong in my first post, but I don't understand from where the values in the red boxes comes Originally Posted by: omorr And where all those fractions come from. I delete them, press equal to - and got the fixed/exponential numbers me too... SMath 0.96.4884 on my notebook... Edited by user 29 May 2013 22:10:02(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
Ah that ... Like I was blind, I did not pay attention on this I just hope that this is only in presenting the numbers, and should not influence on some calculation behavior - I hope . Regards, Radovan |
The trouble comes from the fractions setting in the context menu and how it is processed. If you switch to decimal, then everything is fine. Default setting is "auto". If set to "fraction", then odd fractions are generated, which are far from minimal (or just correct) representations of the given number. Also, for more clarity, I switched on the display of trailing zeros. EDIT: line 8 is same as line 7, sorry, but you still get the point... Edited by user 29 May 2013 16:12:20(UTC)
| Reason: Not specified File Attachment(s): mkraska attached the following image(s): |
on 29/05/2013(UTC), on 29/05/2013(UTC)
Originally Posted by: mkraska The trouble comes from the fractions setting in the context menu thank you very much Martin, this solve my issue shown here (2nd post); the global fractions setting was switched from "Numeric" to "Auto"... ancer: |
