#1 Posted : 15 January 2012 06:51:27(UTC)
Was thanked: 1332 time(s) in 876 post(s)
I think will be useful a function that show if a variabile it's a number (something like the classic isNaN() or also length(var) may be modified to return 0 or 1 in case var is a number)
regards
Edited by user 18 October 2012 16:46:18(UTC)  | Reason: Not specified
Offline omorr
#2 Posted : 15 January 2012 09:41:11(UTC)
omorr
Rank: Administration
Serbia
I agree. As far as I know, there is only IsString() and IsDefined() functions among IsThisorThat() functions available. I believe that other functions like IsArray() or IsScalar() would be useful.
Regarding your question, IsString(arg) function will return 1 if the argument variable -arg- is string variable or function returning string, 0 otherwise (number, scalar, vector, matrix, function returning the ones).
Edited by user 15 January 2012 09:42:41(UTC)  | Reason: Not specified
#3 Posted : 16 January 2012 00:11:19(UTC)
Good
at the moment I'm using this workaround
Edited by user 16 January 2012 00:13:28(UTC)  | Reason: Not specified
on 16/01/2012(UTC)
Offline omorr
#4 Posted : 16 January 2012 01:07:35(UTC)
omorr
Serbia
There is a minor problem with your workaround. Suppose you have a matrix with only one element (this is allowed in SMath)
b←mat(5,1,1)
el(b,1)=5
el(b,1,1)=5
Your function will not recognize it as an array. It may cause problems sometimes, isn't it?
IsArray(Cool=0
EDIT: On the other hand, every array is made by using mat() function i.e.
A←mat(1,2,1,3,2,2)
num2str( A )="mat(1,2,1,3,2,2)"
b←mat(5,1,1)
num2str( b )="mat(5,1,1)"
Unfortunately, I did not figure out how to use all of this to make a IsArray() function which will work with string, scalar and array arguments.
Edited by user 16 January 2012 01:42:04(UTC)  | Reason: Not specified
#5 Posted : 16 January 2012 03:35:05(UTC)
with 1x1 vectors I don't have problems (I'm using SMath 0.90)
Now I've replaced
Code:
num2str(length())
with less expensive
Code:
num2str()
and I've replaced
Code:
findstr("l")
with
Code:
findstr("m")
and I've fixed a little bug with words that contains the findstr argument and a big bug with strings with whitespaces introducing
Code:
IsString()
edit: here there is the file with the two functions IsArray.sm
Edited by user 16 January 2012 03:47:39(UTC)  | Reason: Not specified
Offline omorr
#6 Posted : 16 January 2012 04:31:14(UTC)
omorr
Serbia
Thank you for your efforts. It is a bit tricky and unusual, but works most of the time. What do I mean by that. Just look at the picture (your function used) and it seems to be problematic for the arrays with units and nested arrays.
Maybe some more adjustments? Good
Offline omorr
#7 Posted : 16 January 2012 06:15:48(UTC)
omorr
Serbia
This might be useful, I think.
EDIT: I just replaced the ans with this expression and it works as well with scalar and units (problem was with scalar and units including 'm in them)
Code:
ans:=findstr(_e,"mat(")+1
Edited by user 16 January 2012 09:02:13(UTC)  | Reason: Not specified
#8 Posted : 16 January 2012 11:17:25(UTC)
Great hints Clap
Edited by user 18 October 2012 16:47:17(UTC)  | Reason: Not specified
