2 Pages12>
Offline - Norm -
#1 Posted : 29 November 2017 23:47:22(UTC)
- Norm -
United States
Was thanked: 9 time(s) in 7 post(s)
My first post. I'm trying SMath instead of MathCad P4. RF Resistance. ber and bei.sm (35kb) downloaded 26 time(s). RF Resistance. ber and bei.xmcd (200kb) downloaded 15 time(s).
Having difficulties transferring the RF resistance sheet from MC15. The ber, bei functions are missing. I added plugin EFI for Mathcad for the "Jv" (vs. Jn) function but it doesn't appear in the listing of available functions.
Attached is the mc file and my attempt to transfer to SMath.
I welcome the collabs help to move forward.
Sincerely,
nasch
#2 Posted : 30 November 2017 01:05:03(UTC)
Check if you can do something from the Smath built-in
mwbessl [i,j,k,y] from the f(x) menu.
Offline - Norm -
#3 Posted : 30 November 2017 04:23:52(UTC)
- Norm -
United States
Thanks, for your reply. Unfortunately, I do not see "mwbessl..." listed. Maybe something that I need to activate? Is there a certain plugin I need to load?
Thanks, again
#4 Posted : 30 November 2017 19:23:56(UTC)
You may have to install from the plugin list.
Click on "Tools", click "Plugins" ... install all.
Otherwise, rescue to "Smath Doctors" ... [Martin, Davide ...]
Bessel Midwest.sm (9kb) downloaded 18 time(s).
Offline - Norm -
#5 Posted : 30 November 2017 20:32:40(UTC)
- Norm -
United States
Thanks, again. Unfortunately, the "mwbessel..." function are not defined. I have 23 plugins loaded, all with green check-marks so I think they are all working. "Install all" is not there.
Then again, I do not have admin rights (my work PC), so that may be a problem?
#6 Posted : 30 November 2017 21:02:34(UTC)
Sorry Collab, can't help + ... hope Smath Doctors catch your pain.
#7 Posted : 30 November 2017 21:27:18(UTC)
Try with my portable distribution, see signature. There, the mathlib.dll (mathcad special functions) is installed and the bitness of the executable is adjusted.
The screenshot below is from the interactive handbook. You find it using the [?] button in the toolbar in the distribution mentioned above.
Goto Plugins> EFI for SMath Studio> Special functions.
2017-11-30 19_23_19-SMath Studio 0.98.6484 - [Section Special functions.sm].png
Offline uni
#8 Posted : 30 November 2017 22:04:14(UTC)
uni
Try this.
Links:
1. Cephes Mathematical Library.
mathlib.dll must be uninstalled (removed manually) from the Mathcad EFI plugin. Cephes Mathematical Library contains same functions.
Edited by user 30 November 2017 22:11:25(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline uni
#9 Posted : 30 November 2017 22:17:14(UTC)
uni
No, you have to set 32-bit version flag for the SMath Studio Desktop exe file.
Links:
1. Matlab C++ Math Library 2.1 (Win32)
Russia ☭ forever
Offline - Norm -
#10 Posted : 30 November 2017 23:22:09(UTC)
- Norm -
United States
Many thanks! "Jv" is now defined. But "arctg" is not. Another plugin?
#11 Posted : 30 November 2017 23:52:58(UTC)
Name of trigonometric functions depend on the function naming type in global settings of your smath studio; in your case you should look for atan
Offline - Norm -
#12 Posted : 01 December 2017 00:11:27(UTC)
- Norm -
United States
Thank you! Now it computes, but the value; Rac(100kHz) is negative. Should be 141.553Ohm/Mi. I need the "angle" function definition from Mathcad. angle(x, y) Returns the angle from the x-axis to a line containing the origin and the point (x,y). Results are in radians between 0 and 2π, excluding 2π.
#13 Posted : 01 December 2017 00:24:09(UTC)
angle(x, y)
NFG ... arg(1+1*i)=45°
Offline - Norm -
#14 Posted : 01 December 2017 00:39:13(UTC)
- Norm -
United States
Using an old MC definition I obtained a better value:
#15 Posted : 01 December 2017 17:40:01(UTC)
These two documents may be of interest next blue moon.
Mostly if you need accurate Γ(x) ... Smath built-in ± 4/5 D
Bessel JY.sm (65kb) downloaded 20 time(s).
Maths Special Gamma(x) 15D.sm (76kb) downloaded 19 time(s).
Offline - Norm -
#16 Posted : 01 December 2017 20:53:48(UTC)
- Norm -
United States
Many thanks!
Offline - Norm -
#17 Posted : 07 December 2017 00:17:45(UTC)
- Norm -
United States
Thanks again for the collab's help. The work sheet displays the same result as MC. AC-DC Resistance Using Bessel Functions.sm (13kb) downloaded 7 time(s).
Now I have a fault using a modified sheet that the "Result is above max. allowed positive number." Capture.JPG. The limit for Rac(f) is 9.3MHz, then the error shows.
The result should be 219 micro-ohm/cm. Why the limit?
nas
Bellow Equiv Resistance.sm (15kb) downloaded 11 time(s).
#18 Posted : 07 December 2017 06:31:46(UTC)
Here, it says ... Jv(,,) not defined.
#19 Posted : 07 December 2017 07:26:28(UTC)
I understand the skin effect from my > 50 years back Electronics.
What I don't understand is the so complicated route to Ohms/MHz.
If you could tabulate some values of that Oms/MHz, I will attempt
a model fit ... something like I did for ITER [Cadarache].
#20 Posted : 07 December 2017 14:40:50(UTC)
Something triggered in the factorization of the ratio be(...)/be'(...) you can make it working with a trick
Guest (2)
2 Pages12>
