Offline omorr
#1 Posted : 13 February 2012 23:52:16(UTC)
omorr
Rank: Administration
Serbia
It seems that function rank() will fail with Symbolic optimization.
S←mat(2,0,2,0,0,0,1,-1,2,5,-1,1,-2,-3,0,-2,-2,0,0,-6,0,0,0,6,6,0,0,0,-4,-4,6,5)
N.r←rank(S)
Symbolic:
N.r=0
Numeric:
N.r=3
None:
N.r=3
Edited by user 15 February 2012 01:06:25(UTC)  | Reason: Not specified
Offline omorr
#2 Posted : 14 February 2012 15:36:24(UTC)
omorr
Serbia
Rather strange! Please look at this picture:
And the associate SMath file rank.sm
Could someone read this SMath file and check it out, please. Compare it to the picture above obtained from my computer.
Why the rank is different for matrix S but the same for matrix A by using different Optimization?
#3 Posted : 14 February 2012 16:46:12(UTC)
I've the same problem using your file... the problem seems to be the matrix dimension (S is 6x5 matrix, A is 5x5 matrix... if you enlarge S adding a new column the difference disappears)
regards
w3b5urf3r
Offline omorr
#4 Posted : 14 February 2012 17:41:31(UTC)
omorr
Serbia
You are right, thank you.
The same happened when we "shrink" the matrix A into the 5x4 matrix. On the other hand rank(A)= 0 only for A equals to zero matrix:
rank(mat(0,0,0,0,0,0,2,3))=0
Nevertheless, it should not be this way - the rank of a matrix should not depend on the Optimization applied. There are some other questionable situations where the result is a zero matrix (all zero values in Jacobain matrix and Symbolic optimization, for example- probabelly a bug as well). I suppose this one is a bug too.
Edited by user 14 February 2012 19:15:36(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#5 Posted : 14 February 2012 19:34:09(UTC)
Thank you! Fixing...
on 14/02/2012(UTC)
#6 Posted : 15 February 2012 00:04:05(UTC)
Fixed.
on 15/02/2012(UTC)
