Joined: 19/01/2012(UTC) Posts: 12 Was thanked: 3 time(s) in 2 post(s)
Andrey,
is there a way how I can force an evaluation of the worksheet trough a function from a plug-in? I found that within RegionEvaluable there is a function called RequestForEvaluation(). I tried to call this function but did not succeed.
I want to have the ability to force a recalculation of the entire worksheet when a defined condition is met.
Next question: Is there a way to close SMath from a plug-in function? In my scenario I want to open Smath with a defined worksheet, read input parameters from a file, let SMath do some calculations, write back the results to a file and close SMath.
Thanks for your help in advance and for the great program!
Regards, Infinity
Hello. Infinity wrote:is there a way how I can force an evaluation of the worksheet trough a function from a plug-in? I found that within RegionEvaluable there is a function called RequestForEvaluation(). I tried to call this function but did not succeed.
I want to have the ability to force a recalculation of the entire worksheet when a defined condition is met. Try this: Code:this.Parent.StartEvaluation(0);
Infinity wrote:Next question: Is there a way to close SMath from a plug-in function? In my scenario I want to open Smath with a defined worksheet, read input parameters from a file, let SMath do some calculations, write back the results to a file and close SMath. There is no built-in ability for such actions, but you can always try to kill SMath Studio process from your instance of the plugin. Regards.
