SMath Studio Forum
Bugs & Problems
[SS-3525] assigning element to matrix resets its size
Originally Posted by: ElSid Here you go Jean. Is this a bug or a feature? Mathcad shows this as a pread sheet [array,NOT vector. is this a bug or feature.
Elsid, Neither a bug, nor a feature. Your Mathcad snippet is NOT a spread sheet. A spread sheet is typical of Excel, it has col/row identifiers. Mathcad shows a display w/o col/row identifiers. It has many interesting features that Smath does not have, mostly as local exploder for plotting. You can plot erf(,) vs x directly. If you assign the project like we do in Smath, Mathcad will display col/row in gray and you will plot row/col. So, Mathcad display [not an assigned creation] ... NO col/row identifiers. A Mathcad creation, i.e: an assigned creation ... col/row identifiers. Many Mathcad Collabs asked about this distinction, I had a copy/paste reply. All that explained, it would a great feature Smath distinguish a display by some kind of non printable distinctive invention . For instance a damier of little yellow/white squares [yellow lovely default Smath 255,255,225] Array or vector.sm (31kb) downloaded 18 time(s).
Was thanked: 4 time(s) in 2 post(s)
Now check this (it is a part of a bigger calculation). If I use equal sign after assignment I get a matrix. If I try to get result again in next line, it magically renders to scalar. Edited by user 28 March 2018 11:28:24(UTC)
Originally Posted by: m227 Now check this (it is a part of a bigger calculation). If I use equal sign after assignment I get a matrix. If I try to get result again in next line, it magically renders to scalar. Please: next time, attach the *.sm document
SMath Studio Forum
Bugs & Problems
