Offline CBG
#1 Posted : 30 April 2018 23:45:46(UTC)
CBG
This example is an automation of the Thiele function
published by Jean in the "Utilities Pts logpts Application" sheet
Thiele_Automatic_Jean_cbg.sm (23kb) downloaded 31 time(s).
#2 Posted : 02 May 2018 01:33:59(UTC)
... refreshed a bit, a note added.
Superb, the piece of automated interpolation.
Thanks Carlos ... Jean
Thiele_Automatic_Jean_cbg.sm (27kb) downloaded 22 time(s).
Offline CBG
#3 Posted : 03 May 2018 00:23:05(UTC)
CBG
Hello Jean,
Please review the following example that you posted.
Thiele Model Construct.sm (45kb) downloaded 17 time(s).
Thank you
#4 Posted : 03 May 2018 16:37:19(UTC)
Hello Jean,
Hello Carlos,
The attached document has been doctored.
The long native form is as nice to export than the reduced J_Frac.
J_Frac is more compact, but not as clear for unfamiliar user.
Thiele is capricious wrt to Maple [see the blue note].
It starts refusing if too many Maple instances have been invoked,
maybe a limited courtesy from Maplesoft ?
Please let me know if correct in your Smath system.
See you soon ... Jean
From fresh Smath session, supports the 3 documents attached.
Thiele_0 Demo.sm (58kb) downloaded 18 time(s).
Thiele Transit_Convert.sm (14kb) downloaded 17 time(s).
Thiele Model Construct Copy.sm (38kb) downloaded 18 time(s).
Offline CBG
#5 Posted : 10 May 2018 00:39:36(UTC)
CBG
Hello Jean
Updated version of Interpolation using the Thiele algorithm in cuntinuous fractions.
It includes the calculation of the inverse differences φ [x0, ..., xi], obtained from the values in the known points
Rounding the values of the inverse differences for the purpose of presenting the equation to make it shorter
Thiele_Automatic_Jean_CBG_R1.sm (70kb) downloaded 18 time(s).
#6 Posted : 10 May 2018 16:37:06(UTC)
Hello Carlos,
What a delicious/educative/Engineering piece of work ... zillions thanks !
Reshaped a bit for first time readers.
Thiele_3 Automatic [on error Carlos].sm (37kb) downloaded 25 time(s).
