If you want and can help to the SMath Project by creating a translation for SMath Studio, please, follow the steps below: - Notify developers about it by sending an e-mail on support@smath.info;
- Receive file(s) for translation(s) from developers (it will be txt file of one of the supported language, usually it's English file, if you want another one, please tell this in e-mail on step 1);
- Change received files text-content with yours (recommended) or create a new one. In any case you should save all special chars represented in source file(s);
- Save modified file(s) as shown on screenshots below (the most important thing is that you should use UTF-8 encoding) and then send it back to developers.
Figure 1: Modified file opened with Windows Notepad. Figure 2: Press "File" on Toolbar and then "Save as..". Figure 3: Choose directory where you want to save file. Figure 4: Specify "File name" and UTF-8 (sic!) "Encoding". Figure 5: Press "Save" button to finally save the file. We are allways appreciate you help. Thanks in advance. Edited by user 28 April 2009 07:45:05(UTC)
