Joined: 28/08/2014(UTC) Posts: 1,360 Was thanked: 819 time(s) in 518 post(s)
Originally Posted by: Jean Giraud Hi Jean. Yes, it is ... but just give only one point, because there are only one solution. And the method requires at least one starting point ... Best regards. Alvaro Drag_Jean.pdf (55kb) downloaded 33 time(s). Drag_Jean.sm (50kb) downloaded 30 time(s).Edited by user 23 October 2018 14:09:19(UTC)
Originally Posted by: Razonar Maximization added. Best regards. Alvaro. Thanks Alvaro ... gorgeous solutions. The Draghilev part persists "Syntax incorrect". Don't worry Alvaro: You are doing so much for Smath Community !!!Jean Maths Lagrange Multipliers Alvaro [Maximize-Minimze] Copy.sm (24kb) downloaded 42 time(s).
