SMath Studio Forum
Bugs & Problems
Slow opening due to Background Image
Hi, I am using the SMath for a while, and I really like it. First of all, I would like to thank you for all your efforts. After I started to using latest version (0.99 - 6839), my files with background images are opening very slowly. Also after the file is opened, any action that I make takes longer than usual. I used the same background image with the older versions but I didn't have the same problem. I am attaching the same file with and without the background image. In my computer, it takes to 10.673 sec to open the file with the background image, and it takes less than a second when there is no background image. BackgroundTest_nobackground.sm (17kb) downloaded 16 time(s). BackgroundTest.sm (2,204kb) downloaded 18 time(s).Edited by moderator 06 November 2018 23:08:41(UTC)
| Reason: marked as Fixed
I opened your files with the latest beta of Smath. The slowdown is much more modest than what you have indicated. I note the size of the two files that the background image is very heavy (about 2 Mb ) and from what I see does not seem justified for the background you get: I think you can do a reduction operation (externally to smath) and optimize the file sergio
Hello. Workaround suggested by Sergio works for me. In addition I would suggest to use the latest features implemented in SMath Studio: Header/Footer and Full page background together with correct margins. Here is what I get as a result: BackgroundTest_mod.sm (398kb) downloaded 29 time(s).Regarding performance - I will fix it soon. Best regards.
on 30/10/2018(UTC), on 30/10/2018(UTC)
Thanks for your replies. I will try Andrey's file.
But just for future reference, I downloaded an older version (0.99 6671) and tested another file which is larger (11 pages, same background image, similar amount of calculation per page) it is opened less than a second. Please don't get me wrong, besides the things that I did not do in an optimal way, I just wanted to let you now there is an interesting performance issue. Thank you very much again for your quick replies.
Originally Posted by: Andac Lulec ... files with background images ... I guess I don't understand what is a "background image" in your demo. 2 MB for those 3 gadgets ... Oh !
Jean, this is just an example. User may want to use image with even more resolution because of different reasons (i.e. requirements in the company). The main question is that SMath Studio should be prepared for such situations.
So, it is something to be done in any case.
Performance issue fixed in the latest stable version.
on 06/11/2018(UTC), on 06/11/2018(UTC)
Originally Posted by: Andrey Ivashov Performance issue fixed in the latest stable version.
Best regards. Thanks a lot Andrey. It works great
SMath Studio Forum
Bugs & Problems
