Offline Ninoslayer
#1 Posted : 12 October 2012 18:33:52(UTC)
Ninoslayer
Hey. I liked so much Smath. But I have a problem. It is not vital but if i can solve it i will write my equations very easily. I can't select the unit with "Tab" key. For example when I will write 5*m/s^2 and when pressed "m" it shows me meter to select but for this i must double click to "meter" or press tab. When I double click it works perfectly, but when I press "Tab" for quick input It does not do my job. I use Ubuntu 12.04 with mono 2.10. If someone can help me i will be very pleased.
By the way; I ran program from terminal but it does not produce output.
Offline Gluhm
#2 Posted : 15 November 2012 17:10:24(UTC)
Gluhm
I can confirm this problem. Using Ubuntu 12.04 with latest mono-libraries.
Offline masterRHK
#3 Posted : 17 December 2012 10:57:42(UTC)
masterRHK
United States
I have the same problem.Sad Sad Sad Sad Sad Sad Sad Mad Mad Mad Mad
I used SMath on windows in the past, which I learned to use and enjoyed AND the tab key worked for units.
I have become a user of Ubuntu, I am using Ubuntu 11.04 with the latest mono and loaded SMath, the TAB DOES NOT WORK TO INSERT UNITS. It spoils SMath and my interest to use it.Sad Sad Sad Sad Sad Mad Mad Mad
I need a solution, help help!!!!!
Offline fractal618
#4 Posted : 22 September 2013 02:34:54(UTC)
fractal618
United States
I also have this issue with Linux Mint 15.
It seems to be a problem with Mono, I will post the bug on their forum as well.
