This Smath session is nearly immense but only 25 sec in my steam engine laptop. It is rich of utilities and model functions. The original data set from Viktor aimed at Mathcad Minerr parameters to the ODE system ... That, Smath can't do directly but indirectly very simple. For this particular Kinetics, nice data from ODE are just data, not analytical as such. This session attempted to all the Kinetics be expressed in analytical functions ... done. Naturally, the job will have to be re-done for other Kinetics parameters. The difficulty is around fitting model function to each Kinetics branch as well as to those of their derivatives. That last part is RemToDo. Observe carefully the A, B, C Genfit. From robust to difficult via the technique Genfit-Observer. Just too bad I know nothing about Kinetics ! Will surely guide Kinetics Designers of that style ODE. Cheers ... Jean Genfit Kinetics [Viktor] Copy.sm (289kb) downloaded 42 time(s).
on 03/01/2019(UTC), on 04/01/2019(UTC)
Originally Posted by: Jean Giraud That last part is RemToDo. ... suite/end => last two model fit D2(x), D3(x) Genfit Kinetics [Viktor] Copy.sm (368kb) downloaded 37 time(s).
