There is lot more work under the hood. Part: 1 the XFR 4 parameters represents the 23 order 2 segments poly from CIPM. No comment ! Parts: 2, 3, 4 explore these 3 ranges based on the inverse models. An example to calibrate the XTR is given. Roughly, a good installation from reputed suppliers should render ± 0.01 °C. Any question, please don't hesitate. Cheers ... Jean Inst_Type Pt100 QWICK Kalcul [-273.15 ... 1200] Copy.sm (120kb) downloaded 33 time(s).
