Please help with the col(1,matrix) function in the attached Smath file. Thanks as always, Reg POINTS PER DECADE.sm (15kb) downloaded 9 time(s).
Originally Posted by: Regulation Please help with the col(1,matrix) function in the attached Smath file.
Just the opposite col(matrix, col#) POINTS PER DECADE.sm (19kb) downloaded 10 time(s).
Originally Posted by: Regulation I apparently can't read either.Should be col(FF,1 In the returned document: set 15 decimals The M matrix construction/display is all OK BTW, OK means "0 Killed" marked in the War log book
