Is it true that exportData.CSV[matrix,"filename"] will not overwrite the csv file "filename" and the original file "fiename" must be deleted or moved from the folder to which you are trying to write the csv file?
Thanks, Reg
Seems to be working now with no changes to code. There are gremlins in my computer.
