Joined: 20/03/2019(UTC) Posts: 73 Location: Mandeville, LA
There are no commas separating the thousands, millions, etc. in the numbers. How do I add automatic commas to the numbers? Edited by moderator 27 March 2019 21:00:43(UTC)
| Reason: title edited to fit the argument and for better search indexing
I'm not aware of any way to do this. |
Originally Posted by: Britt1 There are no commas separating the thousands, millions, etc. in the numbers. How do I add automatic commas to the numbers? That type of separation is not normalized in maths. No CAS has that type of separation, unless from gyzma. Just forget it.
Joined: 27/03/2019(UTC) Posts: 75 Location: coah Was thanked: 27 time(s) in 22 post(s)
I miss the HP41 commas separating the thousands
Originally Posted by: churichuro I miss the HP41 commas separating the thousands What I'm saying is that thousands separator is not machine code. Under the hood, your HP41 thousands separator is silent gadget display.
