Hi, I'am not able to use the assume function. Currently Maxima 5.42.2 is used. I would appreciate any ideas Thanks, Lorenz
Originally Posted by: LorenzAl I'am not able to use the assume function. There are 17 ODEsolve in Smath that will do.
Joined: 15/04/2012(UTC) Posts: 1,989 Was thanked: 1128 time(s) in 724 post(s)
Thanks, Lorenz
Can't reproduce. You might want to use symbolic evaluation for the assume call. |
Joined: 28/08/2014(UTC) Posts: 1,367 Was thanked: 826 time(s) in 523 post(s)
Also, can work with complexes ... MaxODE.2.sm (18kb) downloaded 18 time(s).Best regards. Alvaro. Edited by user 05 April 2019 10:14:40(UTC)
Hi Everybody, thanks a lot.....I forgot to evaluate symbolically the assume command.... Edited by moderator 05 April 2019 13:56:43(UTC)
| Reason: marked as solved
