Offline mgklein
#1 Posted : 23 May 2019 21:53:20(UTC)
mgklein
Rank: Member
Brazil
Hello.
I've been following several posts for Q&A for some days about my doubts, but one about Units is not yet solved.
I've been trying to solve a simple problem for air density to practice.
The units always stand in my way and I am interested in how you guys would solve this: ignoring units and not using the built-in constants or make everything converted before handling the problem?
My sheet and the problem I'm trying to get the same results are in the images below.
Is there a way to make the function in a programming line ? Like the other software?
Couldn't get the answers by other's questionings.
Thanks in advance.
Offline uni
#2 Posted : 23 May 2019 22:18:03(UTC)
uni
Try this.
Barometric formula.sm (10kb) downloaded 11 time(s).
Russia ☭ forever
Viacheslav N. Mezentsev
Offline mgklein
#3 Posted : 23 May 2019 22:23:32(UTC)
mgklein
Rank: Member
Brazil
Thanks!
I'll try it myself and see if it works.
Offline uni
#4 Posted : 23 May 2019 22:27:09(UTC)
uni
As for the odesolve block it not yet finished. You must use functions like rkfixed() to solve the ODE.
Russia ☭ forever
Offline mgklein
#5 Posted : 23 May 2019 22:38:19(UTC)
mgklein
Rank: Member
Brazil
Good to know.
I'll try it.
Thanks
#6 Posted : 24 May 2019 01:36:46(UTC)
Just lost my long reply ...
The only possible programming line is the conditional .
NO software can't calculate otherwise than by segment
because Air is not an homogeneous media. So, NO single
formula, NO ODE can represent.
The attached will give you specific kg/m³ up to 85 km geopotential.
Naturally, don't put any units in there. Append unit in result.
Please don't hesitate for more Q & A
The 3 segments collected page 6/6
Inst_ISA.sm (139kb) downloaded 20 time(s).
#7 Posted : 24 May 2019 02:43:12(UTC)
Maybe there was a typo in the attached document.
Please: check, correct as needed.
Offline mgklein
#8 Posted : 24 May 2019 03:36:56(UTC)
mgklein
Rank: Member
Brazil
Thanks.
I'll study the document.
#9 Posted : 24 May 2019 06:22:17(UTC)
The J(x) upper segment was borrowed directly from Mathcad 11.
