Offline Ale16595
#1 Posted : 04 December 2019 21:08:53(UTC)
Ale16595
Hello everyone!
I have difficulty plotting the function c which depends on the derivatives of two functions which in turn depend on the parameter t.
Could anyone help me? This in the smath file.. curvatura.sm (12kb) downloaded 16 time(s).
Thank you so much
Offline oscampo
#2 Posted : 04 December 2019 23:37:09(UTC)
oscampo
Colombia
Was thanked: 97 time(s) in 71 post(s)
Originally Posted by: Ale16595 Go to Quoted Post
Hello everyone!
I have difficulty plotting the function c which depends on the derivatives of two functions which in turn depend on the parameter t...
Maybe this is what you want...
... and the .sm file: curvatura1.sm (10kb) downloaded 22 time(s).
#3 Posted : 05 December 2019 00:19:46(UTC)
Was thanked: 983 time(s) in 811 post(s)
Could anyone help me ?
To plot both systems ... Jean
curvatura.sm (12kb) downloaded 36 time(s).
Maths Tangent.sm (92kb) downloaded 37 time(s).
Offline Ale16595
#4 Posted : 05 December 2019 14:37:36(UTC)
Ale16595
thank you very much for your help, I hope I have no more problems
Offline oscampo
#5 Posted : 05 December 2019 17:20:31(UTC)
oscampo
Colombia
You´re welcome.
It's okay to ask, because you express the need to know. It is better to ask than keep silence
Offline Ale16595
#6 Posted : 06 December 2019 15:21:28(UTC)
Ale16595
Thank you very much for the availability.
But I need more help.
How can I draw the tangent line to the equation in parametric form?
this is the file … curvatura2.sm (13kb) downloaded 20 time(s).
Offline Razonar
#7 Posted : 06 December 2019 18:48:15(UTC)
Razonar
Uruguay
Was thanked: 921 time(s) in 586 post(s)
Hi Ale. Here, some ways.
curvatura3.sm (26kb) downloaded 24 time(s).
curvatura4.sm (21kb) downloaded 30 time(s).
on 06/12/2019(UTC)
#8 Posted : 06 December 2019 19:08:58(UTC)
For the Tangent over C(t), it will follow the scalar rules
of the document Tangent.sm posted before.
The Tangent over the parabola is another business.
Smath does not derive linterp(x) as it is NOT a function
only an interpolation. This project and lot more are
rescued via Infinitesimal Analysis [dates back before CAS].
For that particular typical user point of tangency, OK.
You may want to experiment more .
Don't mind to see noisy curvature [disabled in collapsed].
Chers ... Jean.
curvatura2 Copy.sm (31kb) downloaded 18 time(s).
Offline Ale16595
#9 Posted : 06 December 2019 19:16:01(UTC)
Ale16595
Thanks for the answers.
But if I wanted to find the tangent to the curve when the parameter t changes, how should I do?
Offline Razonar
#10 Posted : 06 December 2019 20:05:01(UTC)
Razonar
Uruguay
Do you mean the envelope, all the tangents for the range en T?
curvatura5 - envelope.sm (24kb) downloaded 31 time(s).
Best regars.
Edited by user 06 December 2019 20:52:48(UTC)  | Reason: Not specified
on 06/12/2019(UTC)
#11 Posted : 06 December 2019 20:55:53(UTC)
Thanks Alvaro ... superb/saved ... Jean
#12 Posted : 06 December 2019 21:02:35(UTC)
Ellipse otherwise from complex.
Circle Complex [Ellipse ROT].sm (14kb) downloaded 22 time(s).
#13 Posted : 07 December 2019 04:48:04(UTC)
Your project has been refactored strictly on discrete.
OK, you have functions but life is from collected data.
Collected data are always noisy from the quantization,
a small amount of Gaussian Ksmooth is often sufficient.
Ksmooth being applied before cinterp
As exemplified, cinterp is the best interpolator for
a clean curvature plot from infinitesimal maths.
I don't understand what your were attempting c(t) last module.
Please, don't hesitate for more.
Maths Tangent Data Set Copy.sm (37kb) downloaded 21 time(s).
on 07/12/2019(UTC)
#14 Posted : 07 December 2019 05:22:41(UTC)
O
.... more maths are coming:
cumulative integration, arc length
derivative you already have it from last attachment.
Offline Ale16595
#15 Posted : 07 December 2019 12:12:23(UTC)
Ale16595
Thank you very much for the help, I appreciate it very much.
I hope to be able to continue alone.
kind regards
#16 Posted : 07 December 2019 16:48:24(UTC)
kind regards
Your project now all done, based on discrete collected data,
collected data that you will have to smooth [not offered].
Smoothing is a large Engineering tool box !
Let's see the continued adventure.
Maths Tangent Data Set.sm (61kb) downloaded 27 time(s).
on 07/12/2019(UTC)
Offline - Norm -
#17 Posted : 20 September 2024 04:40:49(UTC)
- Norm -
United States
Was thanked: 9 time(s) in 7 post(s)
Hello Alvaro, Is graphing a tangent line as exhibited in "curature3.sm" only available for a plot/function in parametric form, i.e. is this available for a cartesian plot/function?
I welcome your review and look forward to your reply.
Sincerely,
Norm
Offline Razonar
#18 Posted : 20 September 2024 13:35:36(UTC)
Razonar
Uruguay
Hi Norm. You can parametrize f(x) as {x(t)=t, y(t)=f(t)} and substitute in the formulas x'(t)=1, x''(t)=0, x(t) -> x and y(t) -> y(x).
curvatura3 - Cartesian.sm (41kb) downloaded 14 time(s).
on 22/09/2024(UTC)
Offline - Norm -
#19 Posted : 21 September 2024 05:00:58(UTC)
- Norm -
United States
Thanks Alvaro! As always, great examples to work with!
Sincerely,
Norm
