2 Pages<12
Offline MarB
#21 Posted : 11 December 2019 19:31:21(UTC)
MarB
Was thanked: 21 time(s) in 17 post(s)
Hope this document will tranquilize visitors/users !
Jean.
If that's what you think.
#22 Posted : 12 December 2019 01:05:16(UTC)
Does it work for you ... SS 7251 users please confirm ?
Offline CBG
#23 Posted : 12 December 2019 03:25:41(UTC)
CBG
Hello Jean
Yes, It works
Offline ndtma
#24 Posted : 12 December 2019 06:09:00(UTC)
ndtma
Sri Lanka
Originally Posted by: MarB [url=/forum/yaf_postsm60156_Program-for-Linear-and-Polynomial-Fit.aspx#post60156][/url]If that's what you think.
It works. Thank you MarB.
Offline ndtma
#25 Posted : 12 December 2019 13:41:20(UTC)
ndtma
Sri Lanka
That's my solution
- to separate the functions from matrix building,
- to use vectorize for speed
Apparently, the function f(#x):=1 if n=0 has a problem?. Or is it redundant?
For values n>0, the "otherwise" condition yields correct results irrespective of values in "if" condition.
Please check.
Edited by user 12 December 2019 13:47:51(UTC)  | Reason: Not specified
Offline MarB
#26 Posted : 12 December 2019 13:53:51(UTC)
MarB
just put the 1 into a 1x1 matrix. That's all.
(And if you want to use units with the X Vector, just remove the eval and evaluate symbolically.)
That's my solution
Please check.
Offline ndtma
#27 Posted : 12 December 2019 16:21:08(UTC)
ndtma
Sri Lanka
Hi
Still the same error when n=0.
Better if you can post the SM file please.
Edited by user 12 December 2019 16:25:22(UTC)  | Reason: Not specified
Offline MarB
#28 Posted : 12 December 2019 17:21:42(UTC)
MarB
Sorry, I didn't realize, that vectorize behaves unexpectedly (to me), when the function does not include 'x'.
So I changed f to f(x):=[1+0*x] and now it works. The file is attached.
PolyFit.sm (12kb) downloaded 17 time(s).
I would expect the results of g and h to be the same, and to be a 3 items long vector.
thanks 1 user thanked MarB for this useful post.
on 12/12/2019(UTC)
Offline ndtma
#29 Posted : 12 December 2019 17:49:54(UTC)
ndtma
Sri Lanka
Hi
Now I get same results as yours.
But the result (19.0833) of the Polyfit() function when n=0 ----> Does it have any meaning?
I have no idea. I was only testing it for all possible conditions..
Cheers MarB.
Note: Incidentally, 19.0833 happens to be the Mean of Y vector.
Edited by user 12 December 2019 17:55:26(UTC)  | Reason: Additional checks
#30 Posted : 12 December 2019 19:06:39(UTC)
IMHO ... no need to complicate matters.
Modular design is easier to fix.
More automated is OK if you intend to poly for the entire Planet.
PolyFit (2).sm (47kb) downloaded 17 time(s).
Offline Razonar
#31 Posted : 12 December 2019 21:12:19(UTC)
Razonar
Uruguay
Hi. This is in case you want to interpolate with an horizontal line.
PolyFit.sm (160kb) downloaded 26 time(s).
PolyFit.pdf (749kb) downloaded 19 time(s).
on 12/12/2019(UTC)
Offline ndtma
#32 Posted : 12 December 2019 21:15:52(UTC)
ndtma
Sri Lanka
Thank you, Alvaro.
2 Pages<12
