SMath Studio Forum
Questions
Insert Values Into Existing Matrix
Is there an easy way or built in way to insert values into a matrix? For example if I have a 2x4 matrix and I want to insert a column. How can this be done? Is it possible to sort a matrix so that the columns are rearranged until the specified row is in ascending order? If not is there a way to invert a 2x4 matrix so that the row is now the column. See attached example. Thanks Matrix Manipulations.sm (7kb) downloaded 23 time(s).
Originally Posted by: RFreund Is there an easy way or built in way to insert values into a matrix? For example if I have a 2x4 matrix and I want to insert a column. How can this be done? Is it possible to sort a matrix so that the columns are rearranged until the specified row is in ascending order? If not is there a way to invert a 2x4 matrix so that the row is now the column. See attached example. 1. Insert col(s)/row(s) from somewhere in the attached 2. Transpose/csort/re-transpose. Utilities Matrix Treasury_1.sm (409kb) downloaded 51 time(s).
SMath Studio Forum
Questions
