Offline roman111
#1 Posted : 05 March 2020 13:24:32(UTC)
roman111
Hello. Is it possible to load a picture into the graph as a background? I did not manage to find the direct answer. Thanks.
#2 Posted : 05 March 2020 14:35:59(UTC)
Originally Posted by: roman111 Go to Quoted Post
Hello. Is it possible to load a picture into the work sheet as a background?
1. you must have the image [typical *.BMP]
in either: your Smath file or in C:\
if you don't already have an Smath file ... create one in C:\
2. from the Smath top menu: Insert, Background
... all pages ... from file [browse] ... stretch
Image Cloud Background.sm (207kb) downloaded 35 time(s).
#3 Posted : 05 March 2020 14:45:30(UTC)
... sanity check attached document OK
#4 Posted : 05 March 2020 14:58:43(UTC)
... now => background over entire Smath document
Circle Aperture_OD Gray 245.sm (31kb) downloaded 33 time(s).
What you CAN NO NOT DO ... turn ON/OFF background
Offline roman111
#5 Posted : 05 March 2020 16:01:01(UTC)
roman111
Thanks, but I meant inserting a picture inside the graph (plot) region, under the axis.
#6 Posted : 05 March 2020 17:48:08(UTC)
Much easier: paste the picture outside the graph,
brush over the picture to select, arrow key to slide/adjust-in.
#7 Posted : 05 March 2020 18:37:06(UTC)
... touchy to adjust.
Offline joaobr
#8 Posted : 14 October 2021 13:48:47(UTC)
joaobr
Brazil
Was thanked: 7 time(s) in 6 post(s)
Hi, Jean!
I'm having trouble controlling which object is in front of the other, the XYPLot Region or the image. It seems a random behavior to me. Am I missing something?
Offline PompelmoTell
#9 Posted : 14 October 2021 14:07:52(UTC)
PompelmoTell
It can be done; for example with the Mschart plugin
#10 Posted : 14 October 2021 14:45:09(UTC)
Originally Posted by: joaobr Go to Quoted Post
Hi, Jean!
the XY PLot Region or the image. It seems a random behavior to me.
Image is always on top, probably native Win.
Click anywhere-in ... just the graph.
Cheers ... Jean.
Offline joaobr
#11 Posted : 14 October 2021 15:05:51(UTC)
joaobr
Brazil
Thank you very much, Pompelmo! Haven't tried this plugin so far. It worked perfectly.
Thanks, Jean. By moving the image in and out, it goes behind the graph sometimes, but suddenly snaps to the front. Couldn't identify a clear behavior. Maybe a "bring to the back/front" functionality would be a useful addition to the program.
Edited by user 14 October 2021 15:08:21(UTC)  | Reason: Not specified
#12 Posted : 14 October 2021 19:48:26(UTC)
Currently the top-left corner of each region drives the position. The regions behind are those closer to the top (top to bottom) and left margins (left to right).
#13 Posted : 14 October 2021 21:32:10(UTC)
From recollection, it was on the wish list SS 5346.
Thing in terms of publishing ... no decoration, gyzmas ...etc.
The Mathcad 11 bring to front send to back had no adept.
A good presentation is background colors.
Cheers ... Jean.
ODE rkfixed VALERY Yellow Corn.sm (79kb) downloaded 4 time(s).
Offline overlord
#14 Posted : 14 October 2021 21:59:32(UTC)
Turkey
Could "Bring to front/Send to back" options implemented for all regions??
But on a second thought, it would require tons of code change.
#15 Posted : 14 October 2021 23:39:14(UTC)
Thanks, Jean.
IMHO, for publishing, a document must be as clean/minimalist.
Even a graph with personal logo/photo is too much.
If your document is unique/pure creation in the planet,
OK personal logo somewhere in the document.
I have some of that style [Pt 100, T,J]
What are you looking for, really ?
Cheers ... Jean.
Online Razonar
#16 Posted : 15 October 2021 07:02:47(UTC)
Razonar
Uruguay
Was thanked: 826 time(s) in 523 post(s)
Hi. Another way, in addition to the one proposed by Pompelmo:
https://en.smath.com/for...-images-into-a-plot.aspx
on 15/10/2021(UTC)
