Joined: 30/03/2020(UTC) Posts: 31 Location: KU Was thanked: 3 time(s) in 2 post(s)
Hallo zusammen, is it possible that a multiple login to cloud (https://de.smath.com/login.aspx) is blocked? cannot log in from Ipad ( or other browser on same device) Wrong login/e-mail or password. Check you credentials and try again. pw is definitely not wrong. Very annoying, because the login remains even if the PC is logged off and who thinks about logging out because he might want to log in with another device. It seems that I can only login by restore access - once logged out I can not get a login again Is there a difference cloud/forum account? Edited by user 29 April 2020 13:10:34(UTC)
Hello. Originally Posted by: hawe Is there a difference cloud/forum account? Yes there are two different credentials: one for the forum and another for SMath Studio Cloud. This is because I'm using third-party forum engine and it is pretty complex thing to switch forum so it will use another authentication engine. Hope it will help you.
Originally Posted by: Andrey Ivashov Hello.
Hope it will help you. It explains at least why I have access to the forum and problems login to the cloud. could it be possible that exists 2 cloud accounts with my email address? To login cloud I have to restore access every time I want to login.
