32 Pages123>»
Offline uni
#1 Posted : 26 April 2013 16:20:32(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
X-Y Plot Region
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
XYPlot. Examples.sm (31kb) downloaded 1,584 time(s).
XYPlot. Examples.pdf (155kb) downloaded 1,540 time(s).
XYPlot. Demo.sm (6kb) downloaded 796 time(s).
XYPlot. Demo.pdf (46kb) downloaded 854 time(s).
XYPlot. Text labels.sm (11kb) downloaded 579 time(s).
XYPlot. Text labels.pdf (54kb) downloaded 500 time(s).
XYPlot. Fill area.sm (11kb) downloaded 554 time(s).
XYPlot. Fill area.pdf (85kb) downloaded 462 time(s).
XYPlot. Draw shapes.sm (20kb) downloaded 811 time(s).
XYPlot. Draw shapes.pdf (93kb) downloaded 618 time(s).
XYPlot. Linear polar.sm (57kb) downloaded 326 time(s).
XYPlot. Linear polar.pdf (135kb) downloaded 240 time(s).
3D plots in XY Plot plugin
pMesh.sm (245kb) downloaded 414 time(s).
pMesh.pdf (3,117kb) downloaded 405 time(s).
Functions for grids, meshes and plot surfaces. Support triangular meshes and multiple surfaces in the same plot.
pSurf.sm (316kb) downloaded 172 time(s).
pSurf.pdf (2,254kb) downloaded 145 time(s).
Small piece of code for filled 2-D contour plot in the XY plot plugin.
FillContour.sm (35kb) downloaded 322 time(s).
FillContour.pdf (307kb) downloaded 309 time(s).
Note: '~' is used as a mark for the "range" variable and should only be used inside the X-Y Plot.
Click to enlarge Click to enlarge Click to enlarge
XYPlot.%20Parametric.sm
Links:
1. Dr. Xu's Books .
2. Creating charts & graphics without coding .
Edited by user 14 February 2025 23:06:58(UTC)  | Reason: Not specified
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
thanks 14 users thanked uni for this useful post.
on 26/04/2013(UTC),  on 26/04/2013(UTC),  on 26/04/2013(UTC),  on 26/04/2013(UTC),  on 26/04/2013(UTC),  on 29/04/2013(UTC),  on 12/05/2013(UTC),  on 13/07/2013(UTC),  on 17/01/2016(UTC),  on 03/12/2016(UTC),  on 11/12/2017(UTC),  on 22/09/2021(UTC),  on 29/08/2022(UTC),  on 13/01/2024(UTC)
#2 Posted : 26 April 2013 16:38:29(UTC)
Was thanked: 1177 time(s) in 752 post(s)
Здорово!
I tried some functions (typed to the placeholder):
x - nothing happens
sin(x) - works
ln(x) - crash (perhaps due to undefined values)
any undefined function - crash
previously defined function returning a list - GUI freeze
Edited by user 26 April 2013 17:30:33(UTC)  | Reason: Not specified
Pre-configured portable distribution of SMath Studio: https://smath.com/wiki/SMath%20with%20Plugins.ashx
#3 Posted : 26 April 2013 17:23:34(UTC)
Was thanked: 1396 time(s) in 910 post(s)
Nice work uni Clap
Originally Posted by: uni Go to Quoted Post
You can change only the function for now. Need to figure out a way how to pass parameters to display the graph or do it like in Mathcad.
A way could be to use context menu items (see ConstructorRegion plugin by Andrey)... also the Mathcad mode it's quite interesting...
you can post the plugin code?
Edited by user 26 April 2013 17:25:56(UTC)  | Reason: Not specified
Offline omorr
#4 Posted : 26 April 2013 17:46:39(UTC)
omorr
Rank: Administration
Serbia
Was thanked: 319 time(s) in 268 post(s)
This is a long time waiting feature and I think we are all excited about it Good
Good luck uni Victory
EDIT: I tried it a bit in a "faulty" Mono in Xubuntu. It si working initially although with crashes as Martin mentioned
Edited by user 26 April 2013 17:49:22(UTC)  | Reason: Not specified
Offline uni
#5 Posted : 26 April 2013 17:47:33(UTC)
uni
The code is taken from this book:
C# Application Series - Xu J. - Practical C# Charts and Graphics [2007, PDF, ENG] (link, rus).
I have something removed and added something to get the plugin. I added sources.
mkraska, not so fast Acute Try some number.
Edited by user 26 April 2013 17:57:54(UTC)  | Reason: Not specified
on 26/04/2013(UTC),  on 22/07/2013(UTC)
#6 Posted : 26 April 2013 18:02:04(UTC)
Thank you very much both for the sources and the book Biggrinrinks:
[EDIT] plugins on wiki updated
Edited by user 26 April 2013 18:34:02(UTC)  | Reason: Not specified
Offline kilele
#7 Posted : 26 April 2013 18:45:46(UTC)
kilele
Was thanked: 133 time(s) in 114 post(s)
thank you very much uni!
please look at this post:
http://en.smath.info/for...provements.aspx#post9105
ZedGraph is c# targeting .net20 so it should work both in windows and linux.
Offline Basile
#8 Posted : 26 April 2013 18:56:51(UTC)
Basile
Thank you uni.
This is long overdue.
As you develop it, please have in mind the basic form of axes: Lin-Lin, Lin-Log, Log-Log.
Basile
Offline omorr
#9 Posted : 26 April 2013 19:45:04(UTC)
omorr
Serbia
...Try some number.
Good
omorr attached the following image(s):
Offline Basile
#10 Posted : 26 April 2013 22:22:17(UTC)
Basile
Radovan,
How did you put graph title and axis titles? and axes greater than 1.
Thank you,
Basile
Offline uni
#11 Posted : 26 April 2013 22:58:45(UTC)
uni
Updated. Form formatting is added to the context menu. Changes take effect after the recalculation. You can use system for several functions but be careful (not tested yet).
on 27/04/2013(UTC),  on 27/04/2013(UTC)
Offline omorr
#12 Posted : 26 April 2013 23:39:18(UTC)
omorr
Serbia
Hello Basile
I did nothing else just put a number in the function placeholder, as uni said. It seems that uni just put this example just as a test at the moment.
Lots of user feedback in quite a short time shows that we are very interested in this plugin. It seems that we need to have some more patience until the very appreciated plugin like this become more stable Beta , and than to test it more carefully Good
Offline kaka
#13 Posted : 27 April 2013 09:14:52(UTC)
kaka
Rank: Member
Clap Thank you again.
Last update: XYPlotRegion_20130427.zip
Sources: https://smath.info/svn/p...ic/plugins/XYPlotRegion/
Offline uni
#14 Posted : 27 April 2013 12:54:43(UTC)
uni
Updated.
Edited by user 27 April 2013 16:15:16(UTC)  | Reason: Not specified
thanks 5 users thanked uni for this useful post.
on 27/04/2013(UTC),  on 27/04/2013(UTC),  on 27/04/2013(UTC),  on 27/04/2013(UTC),  on 28/04/2013(UTC)
Offline pol1
#15 Posted : 28 April 2013 08:49:03(UTC)
pol1
Thanks.
The traces & Number Format function is not working for me (Win 7 64 Bit).
#16 Posted : 28 April 2013 10:01:32(UTC)
Updated.
The last update seems to focus on handling lists of plots. The plugin seems to be under heavy construction.
For plotting functions, the xyplotrregion just evaluates the name, without caring for the argument, therefore plotting pure expressions just as x or x^2 fails.
Also, numbers must be pure numbers, not expressions that can be evaluated to numbers.
I guess that the built-in demo shows sort of development target. It would be interesting to know if expression input for plot items and range limits including unit handling are on the agenda. Anwyway, I am looking forward to the next release.
Offline uni
#17 Posted : 28 April 2013 13:13:01(UTC)
uni
Originally Posted by: pol1 Go to Quoted Post
Thanks.
These tabs will be added later. Working on it.
Updated.
Edited by user 28 April 2013 14:48:41(UTC)  | Reason: Not specified
on 28/04/2013(UTC),  on 28/04/2013(UTC)
#18 Posted : 28 April 2013 15:48:50(UTC)
Updated.
Crashing xyplot:
- loading documents created with earlier versions of the plugin
- expressions evaluating to lists but not being lists (e.g. ±1)
Not crashing xyplot:
- using units Clap
empty placeholder produces a line y=x
Is using limit expressions including units (perhaps using placeholders as in old mathcad) on the agenda?
on 28/04/2013(UTC)
Offline uni
#19 Posted : 28 April 2013 17:32:00(UTC)
uni
There is only one placeholder, so I can enter only the expression and nothing more. I don't know whether it is possible to add more placeholders. Limits for the graphs need to be set explicitly (in the formatting dialog).
#20 Posted : 28 April 2013 19:26:50(UTC)
Could global variables be an option?
The user might define or display values of settings like
XYPlot.xmin:0
XYPlot.xmax:3'm -> this would give the independent variable a unit
XYPlot.ymin:0
XYPlot.ymax:"auto" (auto-scaling)
XYPlot.xaxis:"log" or "lin"
XYPlot.title:num2str(n)
XYPlot.xtics:0,5*'m
etc. This would be quite transparent and readable, but could be hidden in collapsable regions if required.
Settings in the context menu might change or override the variable values or restore them to defaults.
Units could be automatically added to the default axis label if appropriate. You could, however, leave proper annotation in the user's responsibility.
Sticking to some naming convention (e.g. gnuplot) would facilitate the usage.
on 03/06/2013(UTC)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
32 Pages123>»
