Thanks for any response - j
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
Hi. Try changing the zoom with the mouse wheel, or it and control or shift. Best regards. Alvaro.
Razonar and Jean thanks for the quick replies, I tried Razonar's suggestion and it does fix the issue! I do like the idea to ensure f(2)=4 and f(-9)=81 to ensure the function works correctly. Jean very helpful as well, I attempted to implement your example and haven't gotten it yet. Not sure if this is MathCad or SMath, I cannot get the "if" statement to work as you have it. So far I get only the "if" "else" from the programming toolbar only. The matrix's work though, so hopefully I get your example working in SMath soon. Edited by user 18 August 2020 19:40:29(UTC)
Was thanked: 21 time(s) in 17 post(s)
Originally Posted by: p0wrTWR ... I cannot get the "if" statement to work as you have it. So far I get only the "if" "else" from the programming toolbar only.
Try "cases" (Custom Functions plugin). By adding two, four ... additional arguments, you can add more if statements.
