Joined: 15/04/2012(UTC) Posts: 1,989 Was thanked: 1128 time(s) in 724 post(s)
The extension manager cannot connect to the online gallery from our school network. That might be due to firewall settings, however, there is no specific error message. What access adress/port needs to be enabled (and how is that done)? Edit: There was a server side problem when the number of installed plugins was too large. Edited by user 23 March 2014 16:21:48(UTC)
| Reason: Not specified mkraska attached the following image(s): |
I can only say that our academic network is going through a proxy server. At the time being, I did not note any problem about Online gallery. Actually, I even do not know where to set all this things, as Martin mentioned.
Regards, Radovan
Originally Posted by: mkraska What access adress/port needs to be enabled (and how is that done)? Program needs to have access to smath.info (IP: 188.143.132.211) by HTTP (port: 80). Regards.
