Offline rook
#1 Posted : 12 June 2013 12:00:31(UTC)
rook
Steps to reproduce:
- download nightly build v. 0.96.4909 (either setup or stand-alone)
- install Data Exchange plugin from online gallery (to enable .tex export)
- save as .tex (worksheet can be even empty)
- exception: Method not found 'System.String SMath.Control.FileContext.getFullName()'
Offline omorr
#2 Posted : 12 June 2013 12:19:07(UTC)
omorr
Rank: Administration
Serbia
Originally Posted by: rook Go to Quoted Post
Steps to reproduce:
Confirmed,
Offline Andrey Ivashov
#3 Posted : 12 June 2013 13:54:53(UTC)
Plugin should be recompiled with updated references to latest SMath Studio assemblies.
Offline turducken
#4 Posted : 16 September 2013 22:35:12(UTC)
turducken
I've installed the latest nightly build of smath (0.96 build 4909) and still I am unable to export to Latex. Is there slightly more direction that could be given for how to get this working until the next release patches this?
Thanks for your help! I'm currently exporting mathcad sheets to mathematica (using this: http://library.wolfram.com/infocenter/Books/7163/)then to latex (a silly work around but it works!). Would prefer direct smath to latex.
#5 Posted : 17 September 2013 00:28:52(UTC)
Sorry, I've totally missed this thread (3 months... Oh myOh my:ohmyGood
I'll fix it ASAP OK
best regards,
Davide
P.S. To make easiest and fastest as possible the debugging please report in the Extensions section the bugs/issues related to gallery plugins (if a thread already exists)
#6 Posted : 17 September 2013 07:06:31(UTC)
BTW it is possible for you to convert and post a tex output from the attached file with mathematica? Biggrin
File Attachment(s):
tex.sm (2kb) downloaded 66 time(s).
Offline pauljmorrison
#7 Posted : 17 September 2013 17:06:35(UTC)
pauljmorrison
United States
I can also confirm this bug and am definitely interested in a solution. Thanks!
#8 Posted : 20 September 2013 00:33:44(UTC)
this 3D can be marked as fixed Good
Davide
Offline turducken
#9 Posted : 20 September 2013 21:57:38(UTC)
turducken
@w3b5urf3r_reloaded: mathematica will not read mathcad/smath specific syntax. I have been copying equation symbols and functions into mathematica only. Also, mathematica uses brackets [ ] for function expressions. So, you also need to painstakingly regex search your documents to remove those (assuming they aren't nested then its a real mess!)
Thanks for your help. I would have responded sooner but for some reason I am not receiving email notifications from this forum (even though my account is setup to receive emails from forums I post in...).
I downloaded the latest build of the registered Data Exchange extension. Everything exports to .tex correctly so far (though I've done merely simple examples like sin(x)).
#10 Posted : 21 September 2013 00:46:26(UTC)
You're welcome Good
My interest is only on how is exported mathematics in latex by other softwares; actually there's no needs to make changes, but maybe someone has done something better and more clearly than me Wink
Let me know if something doesn't work correctly.
Best regards,
Davide
