SMath Studio Forum
Bugs & Problems
Copying a closed area region crashes SMath
Joined: 15/04/2012(UTC) Posts: 1,989 Was thanked: 1128 time(s) in 724 post(s)
Using Ctrl-Drag to copy a closed region crashes SMath. You can just save the (spoiled) work, but no further editing possible. Edit: Seems to be fixed in 0.97.5189 Edited by user 23 March 2014 14:56:49(UTC)
| Reason: Not specified mkraska attached the following image(s): |
I noted that that the closed Area region can not be moved, and I took that as granted. The CTRL+Drag of closed Areas scrashed SMath, that I can confirm as well.
Regards, Radovan |
SMath Studio Forum
Bugs & Problems
