Joined: 15/04/2012(UTC) Posts: 1,989 Was thanked: 1128 time(s) in 724 post(s)
num2str() fails to convert a sum to a string. In the sum(1) example "syntax is incorrect", in the sum(4) example "n is not defined". Edit: This is now BTS issue SS-43 Edited by user 23 March 2014 14:00:09(UTC)
| Reason: Not specified mkraska attached the following image(s): |
I confirm and add some further example. sergio [smath 0.96 (build 4884) W7 64bit]
This is the current state. sum() now can produce symbolic results. num2str() should provide a string corresponding to the unevaluated expression if it cannot be evaluated. mkraska attached the following image(s): |
