Joined: 15/09/2020(UTC) Posts: 9 Was thanked: 1 time(s) in 1 post(s)
Hello everyone. I have an If shown in the image below. I would like that in addition to the result of the equation, it would also be shown from which equation the result originated. It is possible?
Originally Posted by: Leandro Martins I have an If shown in the image below. I would like that in addition to the result of the equation, it would also be shown from which equation the result originated. It is possible? Maybe ... but document is missing ... Ah !
Leandro, for example like this: Leandro.sm (8kb) downloaded 31 time(s).As Jean says help us get help and always attach the smath file with the problematic example. sergio
Originally Posted by: PompelmoTell Leandro, for example like this: Leandro.sm (8kb) downloaded 31 time(s).As Jean says help us get help and always attach the smath file with the problematic example. sergio Thank´s so much Sergio. It´s Works very nice. Next time I will put smath file. Attach the math file only to check my solution. But this is in Portuguese! Memoria de Calculo Monovia.sm (244kb) downloaded 29 time(s).Edited by moderator 22 September 2020 20:31:08(UTC)
| Reason: Marked as solved
Joined: 28/08/2014(UTC) Posts: 1,368 Was thanked: 829 time(s) in 525 post(s)
Hi. Those are very similar to the Sergio (Pompelmo Tell) solution: Best regards. Alvaro.
Often, if/otherwise is more convenient in program. In some applications, program accepts only if/else. Generally < is incompletely determined ... ≤ is completely determined. It may result in an error message or simply an error w/o message. if-else ... if-otherwise.sm (22kb) downloaded 24 time(s).
