Joined: 27/08/2013(UTC) Posts: 19 Was thanked: 9 time(s) in 5 post(s)
May be I'm not using the Jacobian function in the appropriate way, but it seems to me it does not behave as expected. See below. EDIT: SMath version: 0.96 - build 4909 Edited by user 28 August 2013 12:34:14(UTC)
Joined: 15/04/2012(UTC) Posts: 1,989 Was thanked: 1128 time(s) in 724 post(s)
You may consider using the function Jacobian from the Nonlinear Solvers plugin by Davide Carpi. File Attachment(s): mkraska attached the following image(s): |
