Joined: 30/08/2009(UTC) Posts: 52 Location: Australia
Hi, could you add using 'insert' to reverse the direction of the cursor, as in Mathcad?
Also I think tab works better to move between arguments (little squares) in the current line rather than moving between lines.
Greg Locock wrote:could you add using 'insert' to reverse the direction of the cursor, as in Mathcad? Didn't understand what is "reverse the direction of the cursor". Please, explain. Greg Locock wrote:Also I think tab works better to move between arguments (little squares) in the current line rather than moving between lines. Very good idea. Think I'll do it.
smath wrote:Greg Locock wrote:could you add using 'insert' to reverse the direction of the cursor, as in Mathcad? Didn't understand what is "reverse the direction of the cursor". Please, explain. Maybe this? Regards, Radovan |
In Mathcad if the selection box is blue then additional characters are inserted on the right, pressing insert changes the selection box to red and the chracters are inserted to the left.
