SMath Studio Forum
Questions
rounding to the next positve integer
Hello All, is there a way to round down to the next smaller positive integer in SMath? Example: 56.6 --> 56 If yes, how can I do that? Many thanks and best regards, Erwin Edited by user 26 January 2021 13:06:46(UTC)
use the floor () function (for positive numbers) sergio
Originally Posted by: Erwin_G is there a way to round down to the next smaller positive integer in SMath? The Smath round(■ ,n) work numerical, often useful to isolate. If the suite is symbolic, it does not isolate. Then, isolate or transit spool to file for symbolic suite. Cheers ... Jean Maths Round(U,n).sm (6kb) downloaded 7 time(s).
Originally Posted by: Erwin_G Hello All, is there a way to round down to the next smaller positive integer in SMath?
Many thanks and best regards, Erwin Originally Posted by: PompelmoTell use the floor () function (for positive numbers) sergio Sergio is right, floor() is the correct answer. Other functions won't work for your question. Don't bother with other answers. Regards
SMath Studio Forum
Questions
