Joined: 13/11/2020(UTC) Posts: 28 Was thanked: 7 time(s) in 3 post(s)
Hi guys Do you know how to get the number of a row in an array? ie I have a 5 * 2 array, I want to know what is the number of a particular row ¿Cómo se obtiene el número de una fila, de una matriz? How do you get the number of a row, of a matrix? I do not speak English, I hope you can understand me with the following image
Hello Valentino! This snippet downloaded from the forum long time back. Credit to the author, but cannot remember. There may be other short cuts too. Cheers..... |
2 users thanked ndtma for this useful post.
on 06/05/2021(UTC), on 11/05/2024(UTC)
To find the indices of an array of values. Cheers..... Find_Row_Num.sm (96kb) downloaded 26 time(s). |
3 users thanked ndtma for this useful post.
on 27/03/2021(UTC), on 06/05/2021(UTC), on 11/05/2024(UTC)
Originally Posted by: ndtma Hello Valentino! This snippet downloaded from the forum long time back. Credit to the author, but cannot remember. There may be other short cuts too. Cheers..... Thank you very much, it worked perfectly for me, the method you teach is very useful. Thanks for taking the time and sharing your ideas.
Was thanked: 21 time(s) in 17 post(s)
Alternative (needs special functions plugin): Or in one line:
Originally Posted by: Valentino Do you know how to get the number of a row in an array? i.e: I have a 5 * 2 array, I want to know what is the number of a particular row
hey, i have a some problem. i hope someone can solve this problem too. in the first exampe "match" its not working but in the second example it works. i dont know why
in the first exampe "match" its not working but in the second example it works. i dont know why Hi Beyaz, For first warning, row() expect a real pure number for second argument. Your findrows() result is a number with N unit. Due to your second problem; I think commas in your subscripts makes the bug. When they are deleted, your function match() works. Regards PS: Please provide your problematic file next time. Rewriting your entire screenshot is cumbersome. match.sm (11kb) downloaded 9 time(s).
in the first exampe "match" its not working but in the second example it works. i dont know why Hi Beyaz, For first warning, row() expect a real pure number for second argument. Your findrows() result is a number with N unit. Due to your second problem; I think commas in your subscripts makes the bug. When they are deleted, your function match() works. Regards PS: Please provide your problematic file next time. Rewriting your entire screenshot is cumbersome. match.sm (11kb) downloaded 9 time(s). thanks overlord sorry, you are right, next time i will add the file. i tried it but it doesnt work. this time i add the file. vogt.sm (637kb) downloaded 3 time(s).//I solved it like this Edited by user 28 July 2023 22:49:41(UTC)
Your while loop shouldn't produce E.rkx. At least my computer doesn't. There should be an E.rkx output at end of it. I would solve eval() problem like this. Regards
Attach an image of a typical 6 x 4 matrix 4 decimals. From there, say what you want to extract. That will ease the guidance, while avoiding confusion.
hey guys, Your suggestions were very helpful, but is it possible to rewrite the function so that strings are also can be match. Im looking for the Index of "b" ->[2] KLED.sm (5kb) downloaded 1 time(s).Edited by user 05 January 2024 22:39:44(UTC)
The result of findrows() is a matrix, even if there is only one match (exept for no matches, then the result is the number zero) Converting it to a scalar, seems to help. The same could be applied to the overall result to remove the matrix. Yet, there is a shorter way to get the index. This, however, won't work for multiple matches. KLED.sm (7kb) downloaded 0 time(s). |
